Aftermarket Speedo Wiring VSS
It's similar to my Softail except mine has the Control Area Network (CAN) high and low bus lines.
It would appear that your speedo gets its signal from the serial data line (LGN/V wire), now all you have to do is make sure your aftermarket speedo is compatible with that.
I would make absolutely sure that the speedo was for that bike
Its a Velona Daytona electronic speedometer for harley davidson. Apparently some what universal to all or most harleys with a speed sensor. I will email the manufacturer and ask a few questions tomorrow.
Ok. no word from Velona, but I did a little more research thanks to the information you gave me and was able to make a better guess as to which wire I needed to plug my new speedo's speed sensor wire in to. The VSS's 3 wires are the Power, Ground, and Speed Sensor. I looked around for a corresponding wire coming from the ECM for the VSS, but couldn't find anything. So I spliced the Speed Sensor wire [B], from the VSS and hooked it up there with excellent results! My new speedo is programmable so I was able to calibrate the speed. Not sure if the process would be different for a speedo that was NOT programmable.
Thanks for all the help! I'm brand new to bikes so this is all a learning experience.
FezDeluxe (11-22-2022)
Glad it work out.
Again, thanks for all the help. you're awesome
Hello All,
I have a 2013 Sportster,
I got my speedometer wires cut off with a Wirecutter.I wired everything back following the colors on each wire. Now my spedo won't run on or the push start button wont fire up. The bike has power but the speedo and push to start button don't work. Any ideas?? Maybe a relay? I check all fuses and theybare good. Please help thank you all.
jredd29
09-27-2011 04:46 PM
