Hacked, Conversions and Trailering"Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts"
A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Looks good , I have never seen an HD one like that. It is very close to what you would expect. Pictures can fool you but it looks like the nose is longer also. I have a source that may know. I will check with them when I see them
As for the vents, it gets hot in there for a passenger and someone could have cut them in there. It is not factory. Can you get some better pics of the inside and frame mounts? Does it have brakes on it, disk or drum?
