Trailer wiring question
I finished up my Harbor Freight trailer build last night and was doing the wiring while talking to a friend, and he enlightened me about the magic of diodes. My original plan was to have separate lights for turn signals and brake lights, as my reading has pointed out that the electricity will back-feed through the wiring and not allow the lights to work properly. I currently have a jeep with front brake lights for this very reason, so I know this is true.
Anyways, here's what I have now. The top lights are brake only, but can be easily made into running lights and brake if I choose. Bottom lights are running lights and turn.: http://i76.photobucket.com/albums/j3...ps152af10d.jpg What he said is that a diode only allows electricity to flow in one direction. Logically if I put the diodes in the correct places the lights will work right. Assuming that is correct, I'd like to make all lights work correctly, Stop/Turn/Tail, and add a plug to make the top box more easily removable. I was already looking at the trailer and picturing other stuff that can be done if the box was removed. (beer cooler, parts hauler, maybe my dog wants a ride, etc) So, umm, where should I put the diodes? I would think one on each light coming out of the brake side, to keep it from back feeding the harness, meaning 4 total. Right? Here's a few more pictures for the heck of it. Wires are hanging loose in these, it was getting dark and I wanted to snap a few pics before it was too late: http://i76.photobucket.com/albums/j3...ps047a4f85.jpg http://i76.photobucket.com/albums/j3...ps06215bd7.jpg http://i76.photobucket.com/albums/j3...psce1cafd0.jpg |
Easiest way is to get a converter that adds brake light function to your turn signals. I used the one from Biketronics
http://www.biketronics.com/products/...ilStopper.html |
Originally Posted by Fuzzybeard
(Post 11504399)
You are right, saving money is always good! I found it on Amazon for $42 at the time, plus I have the trailer wiring tied directly into the Biketronics module. That way if I have any problems I can unplug it and be back to stock in a few minutes.
This is simplest way to wire your bike to your trailer >> http://www.ridetimetechnology.com/qc...er_adapter.htm
In line Diode wont be needed since your trailer lights are LED ( Light Emitting Diodes ) from what I see in your pictures As long as your turn signal bulbs on the MC are incandescent you wont need a turn signal module. If your MC has LED turn signals then you should have already had one installed |
Joules,
Your in the right direction using diodes. Diodes will protect the delicate electronics on the bike. Should a short occur it will protect the bike and is absolutely necessary. If your competent in electronics you can do it yourself. I would strongly suggest you buy one on such as on ebay. Most auto parts stores carry them. I have the Hopkins #48895. It will make your installation very easy, looking professional and completely protect your bike. It's a straight plug-in-play install except for the wires to the trailer connector. Everything is clearly labeled and should take about an hour. Spend a few bucks cause it's worth it. My 2 cents. |
[quote=FLTR2008TRIKE;11526625]This is simplest way to wire your bike to your trailer >> http://www.ridetimetechnology.com/qc...er_adapter.htm
Will that work on a 4 wire trailer? Just combine the run and brake outputs? Should I add diodes if I use this adapter? |
Originally Posted by FLHProadkill
(Post 11528044)
A diode will do nothing to prevent damage in the event of a short. The easiest way to isolate the delicate electronics of the vehicle from the trailer lights is to use a trailer light module. http://www.hopkinstowingsolutions.co...lid_state.html This unit is powered by the vehicles battery. The individual light circuits do not power the trailer lights, they just provide a signal to the module, the module sends power from the battery to the lights. It does not matter if you have regular bulbs or LED This unit is weather proof (I just installed one on on my car). |
Go with the Hopkins. I have the same setup on mine. No problems for over 5 years.
© 2024 MH Sub I, LLC dba Internet Brands
