View Full Version : Touring Models
- tranny clunks on shift change
- Help! Bike feels squirmy when making left turns
- New Bike - MANY QUESTIONS
- Severe Helmet Itch
- Could I add New Style Bag Lid Latches/Hinges?
- External crankcase breather
- TBW diagram and connection
- Tore down the bike last night...
- Decisions, decisions... '93 EG Classic vs. '80 FLT...
- Speakers stop working intermittently
- Forward facing camera with dvr?
- Replacement windshields - standard or spoiler/recurve?
- Baker's Comp in Bike
- street glide "rims"
- Finally close to making a decision RG or an Ultra Classic
- Shocks, FLHXS, oh my!
- Air Shock oil replacement ??
- Yet, another oil change question.
- Metzeler 880's to Michelin Commander II's - 200/50 vs. 200/55
- Want to swap rear fenders
- Question on tour pack mount for 1990 electra glide
- Who has internally wired bars with heated grips?
- Flhtp
- Stage 4 upgrade to a 103 - worth it?
- Quietest pipes
- Not if, it's when...
- Any advantage to a Power Vision if bike is stock?
- J&S T-Handle or Oil Pan
- $850.00 cam chain tensioner replacement. Should I?
- 90 degree air shock valve extension FOUND!!
- Rear Turn Signal Mounting Question
- Ordered an FP3
- A Review – Custom Dynamics Bullet Ringz
- 14 flhxs saddle bag fell off
- Kruzer Kaddy Assistance Needed
- Exhaust Fitment '07 - '08
- Deleting imported rides in BOOM Navi
- Primary oil amount?
- Bleeding ABS brakes after bar install - manual says it's a dealer trip
- tour pack on or off?
- DIY: Air ride solenoid 6JJ52 question
- Tire Life ?
- Great experience with direct cycle parts
- New or Used
- Well, my lighting issue is pretty much solved...
- Screaming eagle intake filter for lowers
- Radio Install Wires
- V&H Big shot duels can you hear me
- rear fender fascia on electra glide
- Upgrading Soon
- from road king custom
- Trep reset button
- 2010 Street Glide - what do I need to know?
- What to do??? 08 Street Glide @ 200,000 miles
- Anyone else feel the same about their thundermax?
- Cat removal on a 2011 streetglide
- Help needed. bike barely runs
- Minor saddlebag damage... repair or replace?
- tools
- 26" Winter Project Complete
- new shocks
- saddlebag fillers?
- 2-1 header
- Ultra overlay harness removal?
- Zumo 660 GPS and Traffic alerts?
- Custom exhaust
- 2014 SG: battery dead after sitting only two days??
- Converting to heated seat need help
- New shark nose! Lot of questions...
- Fuel Moto Headpipe
- 96 with 255 cams best starting base map for sepst
- Road King Handlebar change
- Cheap Rain Gear Melted ?
- Joined the ranks today
- Wife made me do it.........BAD Nancy!
- 2015 road glide special
- Security light stays lit at some random point during a ride...
- Low voltage
- Props to RC Cycle of Hayward CA
- Break pedal trim
- GMR 577 Cam.....Wow!!!!
- Muffler end cap compatibility
- Metalsports Luggage Rack
- 100k on our 09 Ultra, 30 states and beyond
- 05 ultra - strange feeling around turns and while ridin slightly
- Reversion & Performance questions
- Headlight chime
- Ho Much Is This Bike Worth? 2003 100th Edition
- Solid wheel fitment
- Heated grip question
- Front brakes squeeking. drivivg Me nuts
- New tires.
- How many quarts of oil in each hole at service
- Fuel pump?
- New Chrome Forks Causing Brake Drag
- Painted Inner Fairing
- Hand switches don't work
- Clutch question
- will this rust? what can I do?
- Is anyone replacing their compensator?
- 11 flhx tuning issue?
- SE Compensator on 04?
- bags
- 2015 RG boom audio
- Taking delivery of Police Electra glide
- Injector maint
- progressive 412 shock info needed
- Left side disaster " compensator etc
- Loud noise after putting primary back together
- 12" yaffe bars install
- Transmisson Problems, Again.
- Question for you with 10"/12" apes with stock cables/wiring
- Traded up:)
- exhaust
- Clarion XC1410 amp installation power question
- What's the best way to break up the day?
- shock air pressure
- Rinehart slimlines got pushed back again by Rinehart...
- Electra Glide Bag Lids
- Passenger back rest luggage rack
- J&S Lift Questions
- P0577 Cruise Control Input High
- Will a 2013 CVO fender fit the rear of a 2014?
- 03 roadglide battery drain
- Tour Bike Governed
- u bracket for license plate
- How much $ to rake a bike?
- Dirty Air Fast Up kit
- Saddlebag lock broken
- Top Shop bags/ The factory color match
- This is Baffling!
- Can't Find Infotainment Thread regarding online Manual
- Installing a 2009+Exhaust on an 07. Proper location of the trans hanger?
- fuel moto power vision
- Thundermax on CVO Limited
- Map
- Rear ABS Sensor Location
- Throttle Servo Cover PM vs Kuyakyn
- black bolts
- Red or Amber rear turn signals?
- Stock HP numbers vs stage 1 96"
- Stupid seat question, any helpers?
- don't tell me....
- I'm Back!!!!
- Problem with accessory connector
- Chrome Rear Saddlebag Guard
- Rear turn signals as brake lights
- What does this go to?
- my winter mods - pics
- Theoretical wireless headset/microphone system
- Hard starting Grinding noise
- Rain Sock for V&H VO2 Naked airfilter
- 110 ci
- Wards fan for 2015 twin cooled engines
- Touring Saddlebag Cover
- SE Stage 4 Kit
- Quick disconnect for bags
- Memorial Weekend Trip Problems......with Pcodes and limp mode
- switch cams jetting question
- Comfort Profile Passanger Saddle Bag Guard Kit. 49087-01
- Misfire and bsckfiring when hot
- new 2015 street glide special cpl ?
- Formula Plus Discontinued?
- Major motor problems ?? On a 14 SG
- Street Glide Seat
- touring pack brake lights needed
- Brake & Clutch Lever Install ?
- Need help identifying part I found under bike
- Reach Seat Question
- Trask or a 120r
- Dresser Duals and Rineharts
- Longride Shield, X-Stream vs Stealth?
- Strange Loss Of 5-Speed Gear Oil In My UC2006
- Accent pain on Black Denim
- know what this is for?
- FLHX Throttle Body Connector Issues
- 09 Ultra Classic, tries to start while running
- Screamin Eagle vs Fuel Moto Heads for power?
- Blew one of my Infinity Kappas
- Rear shocks
- Brand new fork seals and left side leaking?
- DNA Megaphones
- Amsoil Tranny only fluid
- Ultra screen
- Tour Pak
- corvette shocks fail
- Catalytic Converter (Again)
- apes for 2015 streetglide special?
- Electra glide full makeover
- Are Toe and Heel Shifter Same?
- Any Dyno numbers with the new 450s
- 2013 Road King Classic spoke nipple size and torque
- 103 to 110 Stage I Kit
- No fork dive
- Fairing Mirror Options
- grease question
- What kind of Saddlebags do I have -fitment?
- Any 6'2" and above guys with Electra Glides/Street Glides running a short windshield?
- Baker and Spectro
- 1st Time at Dragon and Skyway - PIC HEAVY
- 2006 Ultra Classic gear issues
- LED light kits (New Member)
- SG vs RK windshield?
- BOOM Audio Fairing Speaker Upgrade Experience
- How to identify 103 motor vs 96
- Dirty Bird Front fender
- New firmware upgrade issue
- Question about V&H Stage 1 air cleaner
- Results,going from HD SYN3 to M1 syn oils to Spectro Hvy Dty std dino oil
- FLHP Trunk
- Conti Mileage Milestone Plus Tires
- 12 volt power supply
- MCC Seat Mod
- Corbin locking seat Question
- Metalic Wookie Sound Mystery
- Clutch cable broke at 8k
- 23" wheel with raked trees question??
- Inner primary leak
- 2013 Street Glide T&T Fabrications GPS mount
- DIY air ride installed
- bad dad slammed front fender instead of 21" wheel?
- 07 FLHR hard seat
- Buying used 2010 SG, need help and advice
- Radio Interference
- Power Vision Temporary Placement During AutoTune
- 2013 Cylinder shut off??
- Thundermax purchase advice
- Black Denim paint care?
- Slip-on Removal
- S&S Stealth AC Covers
- just finished adjusting neck bearings
- 2003 Road King CVO
- AC/Exhaust upgrade and now oil leak
- Wheel chock measurement-Road King Classic
- Removable passenger backrest for 2003 Electra Glide Classic?
- Different era handling of FLHTs
- How to tell what 18" wheel was used FLHX
- Suspension upgrades
- Help picking a touring model, so confused...Help please.
- Should I get a PC V
- My Hog Tunes Amp and Speakers experience
- 2010 stereo head unit replacement
- RB Racing 2-1 exhaust?
- Help w/ dash lights & speedo
- Ipod location
- LRS, ultra vs windblade?
- Seat recommendations for tall riders
- exhaust chirp
