View Full Version : Touring Models
- 1st Ride after a long winter....
- Wheel Chock question for my SG
- front turn signal connector 04 rkc
- My Shock Story
- 20K Maintenance turns into 2K job
- starting issues after been running
- 04 road king oil leak
- Maybe Trading
- Windshield Bag Suggestions
- to trade or build...that is the question
- passenger cup holder, street glide
- Power commander v distance to empty.
- 13" CycleSmith Apes and few other mods
- intermittent charging problem 2012 FLHX
- Help with mirrors
- Adjusting (Rolling) Handlebars
- Rear Fascia?
- Out with the old
- You might need new tires if…
- '15 Roadglides...What aftermarket bars did you install?
- Bad motor mount??
- regulator install, goop on connectors
- Change the PIN code on a 2015 Harley Touring:
- need some help..
- Halogen to LED ( fog lights question )
- Finally Finished 2000 Road King Overhaul
- 2 Dumb Transmission Fluid Questions
- Recover seat in Fabric?
- Helibars? Who has them?
- Stranded by a headlight.
- slip ons with out rear mounting nut
- Derby cover fasteners
- He lived...
- Progressive adj. rear shocks
- Mufflers/Aircleaner
- Brake fluid type for 07' EGlide?
- Pretty good cam tech read
- cd no eject
- 1984 FLTC tour glide saddlebag lids?
- Anybody have passenger highway pegs?
- radio going to aux on it's own
- Harbor Freight motorcycle dolly ???
- '14/'15 Street Glide Tire
- FLHX oil cooler project
- New apes installed... 14" twin peaks
- Best windshield for 2009 FLHTCU
- Passenger Footboards - anybody used these?
- Screamin Eagle Cam Tensioner Kit
- Looking for Palm Coast FL riders
- Stock Clutch Cable Length
- 11 roadking classic- standard wheel differences
- A few suspension questions
- 2013 FLHTK Horsepower
- brighter bulbs 09 road king classic
- NaviGatorz LED vs. Headwinds LED Review
- Recommendations for half-helmets
- superchip vigilante ez for 2014.
- Any fans of the SE Nighstick Slipons?
- 97 RK spits and sputters
- Screamin Eagle slip-on question
- Trickle charge pigtail from battery... which tender does this plug into????
- Progressive 444 shocks
- Need help headlight trim ring with daymaker
- Why Won't My Ultra Limited Start?
- Check engine help
- after market amp question
- Reckless fairing sits too high
- relocating docking hardware 2009 road king
- throttle body gasket?
- How can I listen music without turning headlight on?
- BadDad Fender Overlay Install
- Considering 2015 RK, questions
- How many Road kings made in 2013?
- 01 Road Glide Idle cable
- 2016 colors?
- Engine Temp Sensor
- Jensen Radio and Faring Speakers Upgrade
- Fuel Cap for 2014 Ultra Limited
- 2014 Limited radio/CB interference??
- Couldn't find any info on this forum
- 2015 SGS-Installed apes, now no power
- Cutting my windshield..
- Cams
- 06 Road King Performance
- Wards fans
- New voltage regulator
- 2015 Ultra Limited LED Lamp Settings
- average miles
- Help starter not engaging!
- The problem with music
- Rider Floorboard Spacers
- Cam chain tensioner replacment
- Reasonable labor cost for cam and head swap?
- FLHT 2007 not starting
- Advice Rebuilding 2000 Road King Engine
- commander ii pressure
- Run,Brake Turn signal Module
- Front wheel Suggestion
- Linkage rattle (not shifter pegs)
- 2011 96ci. Injector Angle
- New cfr slip ons
- Performance Question
- Frozen Front Brake Lever Following Brake Line Replacement from Master Cylinder to ABS
- 2010 RG, 200 rear tire rubbing inside fender strut
- Tubeless Tires
- TC88 Cam Tensioner Upgrade
- Fullsac CVO power core mufflers louder than stock?
- never ending "what solo seat to buy" situation...looking at 4
- To stage one or not to stage one?
- Another Rinehart exhaust question...
- Moving passenger boards forward
- Back in Action
- Inner primary and primary gaskets
- Just installed new se comp & copensaver !
- Traded my 03 FLSTC for an 08 FLHTCU and...
- Great ride...
- Identify this wheel
- Android App: TwinCam Reference
- Run-Turn-Brake Converter
- I think I'm loosing it.
- HD featured my bike on their Facebook page!
- Observations on my new 2015 Limited Low
- Both O2 Sensors intermittently dropping to 0 Volts
- P1019 Help
- Michelin Commander Wobble
- New tires
- 4" Jackpots sound on '09 Ultra Classic
- Shipping Your Bike
- Brakes & lock tight...?
- New windshield fitment question
- CFRs are In!
- '15 FLTRXS Break-in.
- Love your Road King?
- Fuel Moto AC and the DK Custom breather kit
- Which would be the best battery choice?
- 2014 roadking header pipe
- Full custom hand made seat & razor pak pad complete!
- Putting air in rear tire of 2009 RKC
- Black passing lamp visors part#
- cfr mufflers decibel
- 07 Ultra handlebar Question
- Show me your lowered electra glides (please)
- Simple Spark Plug Question
- Front end shimmy at relatively low speed
- 14 flhxs electrical issue
- stock air shock to progressive 444 ONLY
- enforcer wheels
- No Spark
- Issues with Anderson tour pak relocation
- WTF...Broken clutch cable
- Abs
- Better picture of my CVO
- which speakers do I get?
- Twincam2003-63,000mi
- New Susension Now What?
- Can I program a new keyless Fob for 2015 road glide
- Great Weekend project: Trans Pulley & Cams
- cruise control blues
- Rat Bike/ patina'd bike pics
- All together, dyno'd, and put some miles on.
- E3's to MCII
- Custom paint finished and assembly
- Which Part?
- 2014 "retro fit"
- Has this happened to you ??? Electrical problem ???
- First ride after winter mods (photos)
- Compass in a Pre-14 fairing-
- What would my bike be worth and how hard do you guys think it would be to sell?
- Back in a RK
- 2015 street glide head buffeting
- Seat for Ultra Limited
- BadDad bags and rear fender
- Progressive Suspension Reviews?
- Quick Tune
- Light bar modifacation
- Rush vs Rinehart vs Jachpot
- Long distance touring seat
- code 2013 RGU
- Top motor mount 99-07 twin
- Road King Vs Fatboy Lo
- fast Air
- Road King Seat Question
- Terrible Ride
- Roadside Flat Tire Repair - Kit / Tools / Advice
- New 2015 RGS
- Jackpot vs dresser duals vs power duals and FP3
- Headlight trim ring gap,,,,fix,
- modded handlebars
- please help,
- Vapor lock?
- Radio Switches
- Homemade saddlebag crash bar lights
- Stage 1 questions
- Engine Miss at 2000+ RPM
- Planning a road trip.... How many miles per day ??
- Called a dealership here in Indianapolis about a license plate bracket
- Won't start
- road glide back rest
- Tune myself? or let the shop?
- Thundermax/TBW Sensitivity
- Done with another project
- Extended HD Factory Warranty
- Apes for a 13 FLHX
- BURPING oil for Air cleaner/hoses
- Quick lifter question
- Frustrating Morning
- Rush Slip Ons
- Road King: Fangs vs. Vented Lowers For Buffeting: What's better?
- Saddlebag liners
- American Custom Motors fishtail slip ons
- Security System: Take The Key Fob Battery Poll
- 3 pocket fairing pouch for 14 touring
- hand cramps
- Installed Passenger Back Rest and Rack
- helped a buddy put on his new front wheel!
- 2013 ultra lowering kit and center stand??
- FatBob to new RG?
- ABS...Is it worth it?
- Love Jugs???
- UUgggg... little ping sound
- 23" front wheel pics please
- Trailering Options
- messing with ignition switch and lost power
- Saddleman vs Mustang Seat
- Attn: Jackpot Dyno tuned muffler owners. Baffle questions.
- 2002 RKC Carlini Apes
- Trailer rental in Los Angeles Area
- 2015 SG with 13" Road 6 Customs Holey Rollers
- where to buy chrome lower legs for a flhx
- Sheepskin covers
- 2015 streetglide/not the sg special
- Easy Pass
- Klock Werks or HD Wind Splitter?
- BAS brake light - Parade mode
- Good bye 23" Softail Slim, Hello 2015 RG
- What's the best low profile comfortable solo seat?
- 06 ultra higher bars
- Arlen Ness Inverted Air Cleaner - HELP
- Oil Leak from Under the Engine
- Help me understand this site !!!!!!
- Tail of the dragon and the blue ridge parkway
- new to me 21" renegade Phoenix
- cruise control for flhp road kings
- Spoked rims for a 2014 Road King
- 2012 Touring Seats vs 2015 Touring Seats
- Electra Glide Rear Fender Lights and Cleanup
- Apes on road king question
- what options do I have for turn signals
