View Full Version : Touring Models
- Blowing a fuse with the cruise?
- 50 mm Manifold Question
- Aquatic AV deal
- dragonfly concepts fairing
- razor chopped bags
- info on Harley boom windshield amp/speaker
- 2017 softail slim rear brake applied itself and locked up
- plug wire change
- Should I buy 2015 FLHTP
- CFR guys, which headpipe system with CFRs are you running?
- A long, warranted shout-out to Fuel Moto and Coastal Moto...
- 02 FLHT shocks
- 2009 Ultra Classic Tour Pack Antenna Removal
- 89 flhtp
- At a loss for carb jet sizing??
- Compasses for Motorcycles
- Highway Pegs
- Tuning
- Security System is not accessible
- Will 3.5 Fit?
- What!
- Software or hardware error?
- Back rest for a solo seat?
- Highway Flag mount for HD two up detachable luggage rack
- highway flag mount correct for HD detachable 2 up luggage rack
- audio head for road king
- S&S 4" Race/Tour Mufflers verses Fuel Moto 3.5 Jackpots
- Anyone Haul Their Touring Bike In A Van?
- Handle bars shaking
- Spark plug
- Looking for a fastener
- Custom or aftermarket seat for a Road King?
- Installed DNA CFR KO's
- DK Custom DIY Head Breather on 2009 Ultra with SE Air Filter (pics)
- 2005 Road King Classic Tachometer stopped working, What should be checked?
- RG amp for under seat
- Swapping Wheels
- Enforcer wheel question
- Tour pack light
- 2012 RK Handlebars
- Chopped tour pac price
- Dirty bird air suspension
- 1999 Road King Motor and Paint
- 2000 flhtpi rpms
- Do saddlebag speakers add considerably more audio enjoyment over stock fairing speakers?
- Touring Shock Thread - Lowering
- Really!!! no rebuild kit on Brembo MC and Calipers???
- 2017 Touring shocks
- price info
- Rushmore tour pack on 06 road king
- Some Asshole Stole My Bike
- Laguna Orange
- 2000 E-glide transmission ?
- Tour pack light bar change
- Black Exhaust stains
- Fork wind deflectors with lower fairing??
- Saddle bag fell off
- First service
- Solo seat mounting
- Reckless Fairing's
- 2004 Eglide ignition switch HOUSING
- Refitting Ultra header pipes
- briset51
- 2009 touring changes compared to pre 2009 (Buying delema)
- Do I need load equalizer?
- Not an oil question about Brand - honest
- Towing 2 Street Glides
- New 14" LA CHOPPERS FL ape install
- Low oil pressure and Heating up (2012 FLTRU)
- Cracked oil pan
- Finished cams upgrade the other day
- Has anyone DARED...
- 2013 bags on 2011 RoadKing
- passenger backrest 03 electraglide classic
- 2011 Streetglide speed sensor
- how loud is too loud SGS
- 180 front tire kit done,
- Help with a 2015 cvo limited specs
- '06 fxdli fuel injectors
- 2012 street glide
- 01 electreglide,rear brakes
- 2012 street glide no radio reception
- Holy Crap! It might just happen!
- 2006 Harley Davidson Road King Police FLHPI Luggage
- 91 Ultra Wobble
- Smoked Lens Saddle Bags
- Tour Pal Lid organizer
- ultra engine noise
- Dash lights flickering and 4 trouble codes help
- Road King or street glide
- Lower fairing speaker grills
- the fairing xchange; couple questions
- AVC gone bad on HK system
- tuner cobra vs power commander v
- Wont start
- removing swing arm help
- Question on riding and gearing.
- New add ons
- Can you install a Harley CB on 2016 RGS?
- FM Reception
- stone chip
- 2013 road glide
- Loving the new Cobra exhaust 2013 Ultra Classic
- Which seat is this? Need backrest to match...
- Cirius Engine guard lights
- Revolution True Dual Head pipes
- Should my Road King Classic have started with these numbers?
- 14 in bars
- Buying Ohlins in Canada
- No sound from my radio
- What are people actually paying?
- Need part number for Daymaker headlight well-nuts and screws
- 07 Electra glide running lean
- Changed clutch cable to +6 cable...clutch does not appear to engage
- DUH HD parts guy
- Hog tunes Bluetooth
- Dunlop American Elite Road Test Review
- New Dyna Owner from Austin
- CB Antenna Relocation 2010 FLHX
- 2012 Road King stock mufflers
- 2008 flhtc
- Measuring brake pads
- Lubed RK shifter shaft and removed rear shifter toe
- Installed a LeNale fan last night
- 05 Ultra Classic EG Engine Guard
- After market latches on black denim bags
- GPS on RKC
- Primary chain on a 2000 FLHTCI
- Solid riser bushings for SG
- Need seat suggestions 05 RKC
- Harley ride planner app
- Oil leak
- limp mode
- Floorboards
- Decided on Progressive 444's
- FLHX 2008 Street Glide...
- HD Air Cleaner... Keep it or Replace it?
- Slip ons for 2007 street glide
- cruise control quit
- Idle
- Noise Coming from belt?
- License plate relocate but need to connect LED plate light
- Tips for using two bottle touch up paint.
- 2012 Road King to 2016 Road glide rear fender
- 03 Ultra classic tunning
- High dollar brake pads
- clutch cable
- Looking for a dipstick
- Floorboards
- Vented lowers
- Commander II tires for my 2012 FLHX
- Unplugged Odometer, will I have issues
- 2012 road king
- compass
- compass
- Eating rear wheel bearings
- Electras on the way up?
- grounding problem?
- Not My Week? Twist grip sensor connector pin issue
- 1993 Electra Glide Electrical Issues
- What is #15
- RK with no bags?
- True Duals
- Brake pad replacement Blunder?
- 2009 FLHX Rear Fender on a 2008 FLHT?
- 2006 FLHT gauges, missing two
- Broken brackets upper fairing
- Fly by Wire Throttle Problems.....
- Radio turns off when I hit a bump?
- Uclear Firmware Update
- Is my Clutch adjusted properly?
- HowTo make Passing Lamps work on both low & high beam
- Right leg overheating
- Best place in Chicagoland area to purchase a 2017 RGS ?
- Gas cap hard to twist on
- LED Headlamp
- 27 mpg
- Tbw color connection issue 2012 hd roadking classic
- looking for a picture of Clearwater Darla's on your E-Glide
- exhaust question
- spark plugs porcelain white
- Anyone running Rinehart full exhaust with the new EPA friendly SE Street Pro tuner?
- Simple Rinehart question
- Help with lowers on a 07 roadking
- Klock werks 15 Roadglide
- NO SPARK 2002 Carbed FLHT
- Windshield Bags and Ultra Limited
- Finally, a spring ride on Cape Cod
- Batwing extensions + fork fangs
- from softails to touring
- Evo engine on rushmore frame??
- My gas cap solution
- True Duals
- Dan
- KST handlebars - Buyer beware
- LED Headlamp
- 4 position ignition switch
- New 107 moter whats the deal
- Mirror Question
- Wideband O2 SE Tuner selection for Touring model pre 2014
- Ohlins FKC 101
- 2003 harmon kardon help needed
- V&H FP3 on Sale
- 04 RoadKing, 70K miles....suggestions?
- 2012 RK sound coming from front end
- Anyone regret putting on the piezo siren?
- Road King license plate relocation and bracket removal
- 2017 Road King
- Police seat spanner wrenches
- Anyone use Empire covers?
- DynoJet C3 Android App with PC V
- gutted cat vs true dual sound
- lost cruise control, brake and right signal light on
- Rear blinker bar trouble shooting
- Oil leak from rear head
- Heated seat ?
- XM Module Installation Question
- replacing front bearings on my '97 electra glide...
- Solo seat install
- Saddlebag guard advice
- Throttle assist
- cam upgrade
- Putting together a deal on this bad boy!
- Tire Prices
- Engine temp sensor removal
- Speedometer and Check Engine Light
- 2000 RK FLHRCI Fueling up on rear cylinder
- Anyone make a passanger floor board "Lowering-Kit" 2014 Road King-
- FXR extra large tank
- Street Glide Special 'mini' apes
- Heated Seat???
- 2009 Ultra running rich.
- My experience with Long Ride Shields
- check engine light
- Ultra classic shuts off while riding
- Hard rear brake pedal
- Shout Out to Dan @ Ragan Fab Works
- Mystery Squeak diagnosis assistance
- Brake light switch help
- 2014 Ulta Limited. Wind coming from under fuel tank is choking me!
- Gas Milage - Pleasantly Suprised
- 2012 FLHTK Drive belt alignment question
- 2000+ wheels on a 1999?
- Lower kit for my 2011 flhx
- 2017 Road Glide Ultra colors?
- 2004 Road King new speedo/tach will not install
