View Full Version : Ironhead
Pages :
12]
13
14
- Few more questions on new to me 85 ironhead.
- under crank drain plug
- 78 Sporty Engine Pipe
- half an hour then starteoil light flicker
- runnin ruff
- 2 questions, backfiring, and rebuilding carbs
- Help Needed, Sick Ironhead.
- standard or invervted
- exhaust backfiring
- X$&^%#@$ kickstand!!!!
- Newbie here
- PLEASE HELP!! WIRING DIAGRAM 59' IRONHEAD sporty
- Bad Noises...
- WInter Project
- Need help finding out what year this sportster is
- New guy introduction.
- carb fell off
- wondering about static time
- Swingarm Bearings--Pinion, please?
- need pics of distributor
- Regulator
- Bikes running good, just 2 more questions
- rear motor mount removal
- PIC REQUEST
- throwing flames out the carb
- My first ironhead, lost of questions.
- Tamer II tight fit
- Front/rear pipe temps/plug checks different
- difference
- starting trouble
- Need some quick help please
- Starter and soleniod gaskets
- generator
- distributor
- carb opinions
- oil cooler
- rear motor mount
- Top end parts
- which wire goes where?
- clutch spring.pinion
- clutch issues
- Replacing Oil Lines
- pinion.Should I be able
- forward control options
- Wiring diagram for 1965 XLCH request by KSSportster...
- compensator sprocket..pinion
- need name of part, and where to buy
- heads and cylinders off...
- Need some help with my new 74 Sportster
- question about distributer
- 1965 XLH
- Hand drawn wiring diagram for XLCH...
- Magnetos
- I have no oil flow or pressure
- polarizing a generator
- 68 xlch overhaul
- Some Pics of my 72 XLH
- What do I need to get some front brake action?
- backfiring....
- Early Cam and Sprocket Covers
- Speedo and Tach
- Another issue -- Clutch Slipping?
- Good news and Bad news
- Staticly check timing
- Air Filter problems
- Boging when warm
- plug types for 1969
- Does this ever happen to you guys?...
- Back to timing
- Band head or O-ring head?
- Cherry red pipes
- First ride!
- 74 Brake fluid
- Where have all the 38mms gone??
- Crankcase breather/overflow?
- Carb for 1985 XLH
- Brake fluid
- weird electrical problem.. early 84 XLH
- fouling out spark plugs
- It's ALIVE!
- Please help! How much is this worth
- New to me 74 Ironhead
- sportster ping(?)
- Can Siamese Exhaust fit on my 1980?
- coil problems!!!!!!!!!
- WOOO HOOOO!!!
- Generator Not Charging Battery
- White Wall Tires?
- Rear Sprocket replacement for 83 ironhead
- clutch won't disengage
- Mikuni Tuning
- lion in winter
- exhaust pipe legnths
- Transmission stuck in 4th
- 1 tooth
- Is Mikuni 42 too big for stock 1000cc?
- Front Brake Shoes for 72 XLH?
- Rebuilding -76 Showa fork, need help.
- the speedometer headache
- Oil in exhaust
- 77 Sporster Starting Problems
- Ironhead For Sale
- Seating Issues
- Oil and Tranny Fluid in a 67 Ironhead
- XLH HI-FLO CARB & AIR CLEANER kit
- S&S carb adjustment
- 75 front caliper
- gearcase breather tube
- Ironhead aftermarket parts?
- Early Sportster 18" replica rims, V Twin
- 300 miles from home with broken chain
- Solenoid installation
- More clutch woes
- main shaft key sheared?
- more broke sh!t
- oil tank and hoses connected the right way?
- Crankcase Vent - Leaking oil when hot?
- Pushrod tube cover.
- Stripped crankcase plug
- Oil leaks- 76 sportster
- front brake upgrade (dual discs?)
- 79 Heads
- '75 XLCH Clutch wobble
- got the ride on da road
- 1972 SPORTSTER XLCH generator
- ironhead ignition problem, help needed
- Leaking Carb
- clutch problem
- Pushrod double-check XLCH '71
- parts advice
- Transmission question
- Advice needed. Rebuild? Or replace?
- Exhaust sytems for 79 Ironhead
- fuel line
- fixin' things
- Electronic Ignition 68 xlch
- New carb/Old motor
- cam gears
- 1984 SPORTSTER FOR SALE $2900.00
- fork measure ?
- a new Ironhead owner
- Kick Starting made easier?
- 83 sporty primary vent leak
- fuel shut-off
- Bad generator, but what part?
- Backfiring 84
- Advice.. rebuild IYO
- blowing smoke from my exhaust
- two ironhead questions...
- rear chain to belt conversion
- 21 inch front wheel needed
- Clutch
- hardtail or extended swingarm
- 76 Ironhead
- clutch issues
- New carb
- 79xls bore?
- 76 Sportster help needed!
- 79 xls overfill?
- starter brace
- starting up after the unfreeze
- 75 XLCH
- oil pressure issue
- transmission mainshaft
- Replacing wheel bearings
- carb popping on 80 iron head fixed
- Mallory electronic distributor
- Carb. Coughing (Piniongear)
- cam cover ???
- Old tyme tune-up
- iron head clutch headaches
- 79 xls ( Does that mean Roadster)
- Point gap
- DOES ANY ONE HAVE A THROTTLE CABLE
- 84 ironhead wont idle
- iron head primary cover gasket
- Battery poor man fix
- what model?
- Wheel Size?
- Question for piniongear
- sneaky starting problem
- cracked starter endcap
- regulator damage
- Oil Level - 1972 XLH
- battery question
- stuck in gear and aint going anywhere
- Primary Nut, etc...
- Electrical Questions 1972 XLH
- Battery Cable Question
- tachometer options?
- Mikuni HSR42
- NJ title / registration question
- it's time to put it in the stand i made
- Oil Questions
- 67 Ironhead... Let me know what you guys think
- Choke closing
- '78 Sporty/bleeding front calipers
- 1000cc poping?
- Oil question...
- Installing Intake Manifold
- what weight oil
- 75 turn signal problem?
- Color Pictures
- battery eliminator (large capacitor) on xlch
- 1973 Ironhead Sportster
- Finally!
- 76 liberty edition info
- Dirt bike Sportster
- Some photos of the finished 74 XL...
- Any links on a starter unit for a 70's XL
- late 84 sportster - Need rebuild pdf
- Jetting Suggestions
- wont start when hot
- Starter question
- 75 xl forsale
- oil temp gauge
- Shovester
- Ironhead Mikuni VM 38mm?
- 79 XLS
- 76 xlh carby problems i think
- Is this guy telling me the truth?
- Slow drain in generator or regulator
- Wiring Question for the wire Guru's
- 74 sporster pic
- Quick opinion of tanks.
- compression and carb pop 80 iron head
- Pics of rough 68 sporty
- A question of interest regarding vin numbers...
- Wolf....Your brake plate spacer is made.
- New Bike, whole new set of challenges.
- What to do with a rough 68 XLCH
- 70's gas tank coating?
- Hey all....couple of questions
- ignition switch replacement
- Forward control enxtensions
- IT'S ALIVE!!
- high speed performance weirdness
- Stupid seat question from the King of Stupid
- vibration
- regulator
- new clutch plates
- idea to solve ironhead slipping
- to forum mods
- throttle cable
- Help !!! 81 XLH with Engine Noise
- 81 SPORT TURNSIGNALS
- thanks to all
- 75 ironhead exhaust..pinion.you around?
