Our 750 modification thread
This weekend, we swapped the grill with an aluminum screen from Stonefree manufacturing. also put some front axle nut covers on.
I'll add pic of the grill when they are uploaded but it looks good and makes the size of the road junk that can get to the radiator cover much smaller. we have occasion to ride on dirt and chip roads so while not necessary, it is a nice bit of protection.
EDIT: here is the pic of the grill as well as the new axle nut cover
It looks like you guys have made a few more modifications than we have, but we had some similar ideas.
My wife had new bars installed on her 2015. The stock bars were too low for her. It required a longer clutch cable. They were able to reuse the throttle cables. They should have lengthened the wires for the front brake light switch, and they did not. As a result, the wires kept pulling off and we ended up splicing in a section to lengthen the wires.
She added a "bolt to the handlebars" type windshield which helped cut down the wind a great deal. It was much less expensive than the Harley windshield and did not require removal of the headlight nacelle.
We added a set of Viking Bags. We also added an engine guard and highway pegs. We modified the mounting adapters for a set of Kuryakyn mini-boards to replace the pegs. (It was a royal pain to put those mini-boards on and took a bit of time to figure out how to make them fit, but she likes them much better than the pegs). We also modified a brake pedal cover and added it, both to make it look better and to raise the top of the pedal up some (like some others have noticed, the pedal is a good bit lower than a typical H-D brake pedal.) And the mirrors, of course, were replaced, so now you can actually see what is behind you.
I think she still slightly prefers her Heritage, but she really enjoys the 750.
I'll try to get some pics of it. The ones I have taken don't really show them up close.
The left side went right on, no problem. Since the mini-board's mount can be adjusted to match the angle of the original peg, it was a simple remove/replace.
The right side was the issue. We took parts from another set of after-market boards, then shimmed that with large flat washers to get the spacing far enough out to clear the exhaust and the rear brake pedal lever. If I had it to do over again, I probably would have gone about it a different way, but it worked and my wife was happy with it and basically told me to leave it alone an let her get back to riding! lol
What I think would probably work much better is a chrome spacer that will fit between the mini-board mount and the mini-board, and a longer bolt to attach it with. I think it needs to be somewhere around an inch longer than the normal mounting will clear. (I think that the longer bolt would probably need to be a very strong, high grade bolt to handle the extra stress that the longer mount's leverage would create.)
So far it is working out pretty well, so I won't try to "fix it" unless it breaks. lol
Far out. I'm really looking forward to seeing how the right side is mounted. My wife really likes the feel of the boards on our Shadow. I'm slowly replacing a lot of stress bolts on all our bikes with Stainless button head bolts (mostly from Ace hardware) and they are pretty stout... not Grade 8 but better than the stock.
Try an old socket for a spacer, they work gonzo in a pinch!
