fuel problems with the xg750
..... is the XG another name for the Street 750 ?
... might have more luck w/this question on the actual Street forum
https://www.hdforums.com/forum/harle...on-street-186/
My guess.... you forgot to hook up fuel, a wire connector, or damaged a connector/wire during the fix.....
Best bet is to recheck your work... along with anything moved or touched...
Good luck...
If you used a hose to drain the fuel it may have knocked a wire off the fuel pump inside the tank.
Check all your wire connection you worked with, and check your Fusses on your Street 750.
P.S. Welcome to our Forum, lots of good info here.
John
John
