Chain Conversions for Streets
Wrong. Again.
In terms of efficiency chains are #1 and always have been. Then belts, then shaft drive.
Once more you post this same inaccurate information. Please read this article https://www.motorcyclistonline.com/m...stems-compared.
Then, "at least you'll know the product your [sic] are talking about."
"If belts are so great, why don’t we see them on more bikes? Packaging and difficulty of replacement are the biggest drawbacks. Belts can’t wrap as tightly as chains so they need to be run on big pulleys that wouldn’t necessarily fit on smaller bikes. And when it comes to replacing a drive belt, the process usually entails removing the swingarm. Belts also sap a lot more power than sprockets and chains, so they’re not nearly as efficient."
Sorry, but I'd need to see some actual data supporting the above efficiency assertion. Just because some writer states it, doesn't make it true. The one thing I could agree with, is that with a belt you need more teeth engaged, as such you need larger sprockets, and correspondingly more weight. But, I'm not sure that adds up to "sap a lot more power".
From your reference:
My main point here is to show the correct order that the different systems should be listed.
Gregg - Son, tests have showed the inertia to accelerate a chain is more than a belt simply because of their heavier weight. End of story. Because of their heavier weight they also use more force when changing direction around the sprocket. It is called physics.
Haven't heard from you in a while. Nice to see that you are still stalking my posts. I was getting lonely.
Many consider efficiency a factor when maintenance needs are considered. Even the best sealed chain requires ongoing maintenance.
As for stalking you. I think your ego is a bit inflated. The simple fact is that you post on this forum so often (12,000+ posts!) it's practically impossible to browse the threads and not run across at least one of your posts.
So there you have it. Son.
Received 14,139 Likes
Gregg - So every time you post you browse the softail, Dyna, Sportster, Touring, Trike, Street, V Rod, Pan, Shovel, M8, Rushmore, off topic, road trip and others. BS!
I started checking every time you post your negative comments and what did I find. Your name is always on the last ten who checked my stats to find out where it am posting.
Remember your quality of knowledge resulted in you making two posts that I did not own a motorcycle that I just read and and dream about them. You followed that up with if I even do have a bike and ride I just ride locally on flat roads.
I don't put you on ignore as I find your disturbed mental conditions amusing having had a second major in psychology the other was management.
Remember also that on two occasions with your claims about my cycles would not do what I say they do that I have I offered to ride to your area and demonstrate them to you. You crawfished out demonstrating the cowardly person that you are. That in spite of me offering to hand you the stamped and preaddressed envelope with a $1K donation to St. Jude's for you to mail if they failed.
Have a nice day.
Have a nice day.
Have a nice day.
Have a nice day.
One can only presume you do this to obscure the fact that you have no idea what you're talking about.
Here's an idea. Check and correct your facts before posting false and misleading info on a public forum and no one will be able to question your lack of knowledge.
Simple huh?
