Custom Hagon 2810 Rear Shocks Installed
Took less than 3 weeks from order to in my hands. Built to my specs. These are a bit over 1" longer eye to eye (15.125") than the OEM units. You will have to adjust your belt as it is too slack once these are installed. That will be taken care of when the Dunlops are installed.
And the last pic........I am working with Moroso on plug wires. Working on fitment and build. Super secret squirrel stuff and all.
Went for a ride today. Had to start breaking in the new Dunlops and bed in the EBC brake pads. While I couldn't push the bike like I normally do because of scrubbing in the new tires I can say the Hagon shocks are fabulous!!!! The added length puts a bit more pressure on the front end and it now gives all kinds of feedback. That might be from the Dunlop Q3+'s as well. So, it seems I have made some very good choices between tires, brake pads and suspension.
Now that I have some heat cycles into the new tires, the clutch adjusted well and the all new suspension dialed in (both the Hagon rear shocks and the Ohlins fork cartridges) I'll be hitting my favorite 2 roads tomorrow. This bike has been transformed. Lean angle, traction, cornering stability.....all so much better. I can say that the OEM tires were not only low on traction but poor in profile. Oh, and I just had to get a personalized plate for this rarely seen model Harely.
