I'm rebuilding a flooded XL1200C
#101
At this point you may want to invest in an owner manual for the basics or a workshop manual for other stuff.
The oil is checked with the bike on level ground on the jiffy stand.
You need to check it after the engine has been running. So after you come back from a ride you put in the garage and leave it ticking over for 20 seconds or so and then switch off. Now you check the oil level. If you check in a few hours time the oil will show as low. If you wait until the next day there will be no oil.
It has been found prudent to not fill to the max but maybe halfway on the dipstick. Over filling a Harley engine is a recipe for oil out of the breather.
When oil and water get beaten together you get a white emulsion. I have found the oil gets aerated so you may also see bubbles in it.
#102
#103
QRUCK (12-29-2018)
#104
It actually didn't rain today and the street dried up so I took it around the neigborhood (didn't film it though) and it ran great! I also just disconnected and cleaned the rear brake light switch and it works now! I'll run it a few more times around the neighborhood and then change oils again then it should be perfect! My total cost for this came to just a hair under $2K(that's cost to purchase bike, new starter, new battery cover fender and title).
#105
#106
As suspected, when I checked the oil after the ride around the block it was a nice milky brown and overfilled. Drained it, added more and once it's not raining will take it around the neighborhood again and check. Hopefully it got all the remaining water in the system out.
The only other way is to disassemble the engine, and ain't nobody got time for that.
#107
Awesome that it’s on the road. I would recommend trying to get out as much of the old oil as possible. You need to get the oil out of the case by loosening oil lines from the pump or dropping the oil pump to drain the cam chest as it can hold oil that is contaminated.
Buy a a bunch of cheap oil and keep at it. You may find an oil additive to help a little during the process.
QRUCK (01-01-2019)
#108
QRUCK (01-01-2019)
#109
Received 2,524 Likes
Very good news.
To me, after such projects, when it first cranks it is like the first cry of a new born baby. Sweet!
Maybe after another oil change, it needs to be rode around and get well up to temperature. I would remain local for the mean time just in case something weird comes up.
Also, in the near future, I would replace the brakes, front and rear.
Any bolts or nuts removed need anti seize put on them to resist corrosion from the flood, of course.
Oh, and run a good dose of seafoam thru it when you can.
Congrats, and ride safe!
QRUCK (01-01-2019)
#110
