I'm rebuilding a flooded XL1200C
#51
@RIPSAW tested with the jumper cables, still the same outcome. Engine is turning over if I manually spin wheel. Do you think it could be the starter motor?
That click sounds like your solenoid is moving I think, so it is not rusted fast. My guess is it is the starter. Possible to probably take it all apart and clean it up. Possible it is full of water. Not sure how.
Not telling you do do this, but If it were me, I would bump back tire with starter hit hoping it would free starter with wheel. Plugs out and wires grounded. In low gear, so the starter will not turn the wheel fast if it starts up. The wheel has to be bumped right direction since starter sprag clutch rolls gear out the wrong direction which is how it works to protect starter if someone holds button after motor starts.. Not sure which direction. Be careful.
#53
Unplug that hydraulic brake light switch plug and just jump the plug with a wire to make sure that hydraulic switch is bad. They usually last 30K. Never had one go on a car but Harley's are not quality there. Mine is the 3rd and I got it at Advance with a lifetime warranty.
Do you have a switch at the stand or a clutch neutral start switch? I would not think it would do anything but before you tear down, pull in the clutch, still in neutral and get stand up and try the starter.
#54
@RIPSAW When I had the rear wheel up earlier I made sure to have the stand up and it was still the same problem. I just went out after reading your comment to try neutral, clutch in and stand up, still the same click. I'll be doing research all week to figure out a few different things it could be but I'm sure I will have to pull the primary cover and see what is going on with the starter.
#55
QRUCK (12-09-2018)
#56
I just stumbled across your thread just now . I must say I'm totally hooked on this thread now . My hat is off to you for taking on a project like this . As mentioned above your starter relay should click when you press the start button . If it does then I would check your connector and all the wiring going down to the starter for corrosion and make sure all is clean . If all looks good then I would guess your solenoid is your issue . You may want to remove it and check it on a bench using cables ( hold on tight ) . Good luck , and I'm looking forward to seeing that bike hit the road again !
QRUCK (12-09-2018)
#57
QRUCK (12-09-2018)
#59
#60
Well, I tried cleaning the connections I could find....no dice. Will probably take the primary cover off next time I work on it to see what it's doing then either replace or (hopefully) find the issue.
https://youtu.be/DznRtJLrZ9U
