Fuel moto power vision
Got the PV mounted to the bars & did the first AT run yesterday & all good, thanks for the input here & in particular info from fuelmoto, suppose I'm using these 3 sessions as a practice because in 3-4 weeks time I'm having some hand made custom pipes fitted to the bike & it will definitely need tuning.
Don't know for sure if you have to that's just the way I do it.
paullavery (04-12-2016)
Thanks for that info, between the 1st & 2nd i didn't but i did on the 3rd session, hopefully it will still work ? anyway I've flashed it to the ecm now.
You want to select the Fuel Moto tune in Slot 1. I would start with three, 20 minute Auto Tune sessions using the Auto Tune Basic application. When you enable AT-Basic i would go to Settings on the Auto Tune screen and configure the Min MAP to 30kpa which will help prevent de-tuning the decel area. After each session you will export learned and this will create a new map in the tune manager, for the following session re-enable this map so you will always be working forward. If you need any assistance along the way you are welcome to contact us and we are here to help
This one has never been adequately explained (that I could fine ...and I've asked before)...
If you set the minimum MAP to 30kpa then basically there are parts of the decel area of the map that NEVER GET ANY DATA and therefore NEVER GET TUNED.
This means that whatever canned map or otherwise you started with stays the same ...and it may be blocklocks wrong to start with. The question becomes so how do you tune that area of the tables??
You could interpolate/smooth/blend/whatever the table all the way down into the bottom left but essentially you are guessing.
Personally I don't know if this is old advice and the tuning algorithms of the PV have gotten better over the years, but I left the minimum MAP on default (20) and provided you are smooth with your data collecting my tables came out fine and with no farts pops or otherwise on the overrun.
Best of my understanding that I got from a thread awhile ago. Switching to 30 is something you would do after mapping VE tables. This will keep closed loop trims away from the 20 column. during normal riding. Or if you mapped this area a different way besides stock narrow bands. You switch to 30 before you finish mapping with stock narrow bands.
Or you could just target a AFR that is in open loop in the 20 column.
Since you have it up. I'll use it as an example of blending up. Start in the zero column. Last good know is 72.3. Carry that all the way up to 6500. Take the 2% of 82.8 and carry that up to 6500. Is it perfect to do? No, but we are going to be with in a half point. Are we getting popping? Add fuel in the AFR table. Remember this is decel. No load. The goal here is to keep it from popping. So, how important is it to get them exactly spot on? If you can map these areas with sensor feedback, great. If you can't. I wouldn't loose much sleep.
Gordon61 (01-29-2018)
