Fuel moto power vision
I've watched the installation video for auto tune but I get different screens ?
Firstly do I select my original tune or the one sent to me with the device from fuel moto ?
Secondly, which ever one I select I get this screen with 4 options ?
I'm not sure which of the 4 I should be selecting, also once set up for auto tune how long should I be riding the bike for ?
No one has jumped in yet, so I will put in my two cents, since I installed my Powervision tuner a few days ago. Number three is what it says, a copy of the original tune. You can leave that alone for now. That is the tune that was in your bike ecm when the tuner and bike were married. It seems that your tuner is only loaded with a single tune. Usually, you get at least four different ones. It that tune matches what you have, meaning a Slim, that would be the one to go with and choose that one to flash to your ecm. Besides, since that is the only one available to you, it seems you have no other choice. I am sure Fuel Moto can help you out with other tunes that are a closer match to your bike and the way it is set up. Good luck.
paullavery (04-03-2016)
Hi Paul, if you bought yours from FM then their value add is the great support they offer and they will load a starting map for your ride into the PV before they ship it out. (I don't get trips to the states and/or can't afford the import duty so when I bought mine from here in the UK, it came with no pre loaded custom slots at all )
S-16-110-SLIM-SO suggests a Softail 2016 110 which matches your pic of your Slim S so I'd assume this is the one they sent you to use.
Program the bike with that; autotune that and (if you only bought a basic Power Vision and have not changed your O2 sensors) select Basic/OEM Narowbands.
cheers
cheers
cheers
cheers
I've loaded the map they inc but since then have added a k&n filter so thought an auto tune would be a good idea, I'll go for the Basic/OEM Narrowbands then.
Cheers, Paul.
Then follow the vids on autotuning
happy tuning
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
You want to select the Fuel Moto tune in Slot 1. I would start with three, 20 minute Auto Tune sessions using the Auto Tune Basic application. When you enable AT-Basic i would go to Settings on the Auto Tune screen and configure the Min MAP to 30kpa which will help prevent de-tuning the decel area. After each session you will export learned and this will create a new map in the tune manager, for the following session re-enable this map so you will always be working forward. If you need any assistance along the way you are welcome to contact us and we are here to help
After each session you will export learned and this will allow you to create a new calibration in the Tune Manager. (We generally choose a new slot rather than overwriting and earlier calibration which will allow you to go back to your earlier map if necessary). For the following tuning session you will then re-enable this new map so you are always working forward with corrected data.
paullavery (04-05-2016)
