Fast Idle Solenoid has mind of it's own
I have a friend's 04 RK in my home workshop with a bizarre issue. When the ignition and on/run switches are OFF the fast idle solenoid cycles repeatedly. First thing I did was try to see if it would give me a code. Not only is there no code (no check engine light either) but the speedometer needle does not cycle like it should when first retrieving any codes. There is a constant 10.5 volts going to the solenoid with both switches off (again is this normal?) So with all this in mind is it possible that there may be a wire or connector issue somewhere or does it seem that the ECU has bumed out? Just a small history also, this bike is a 04 RK that is a bone stock unmolested ride with 27,000mi. It has been sitting for 5 years untouched but ran fine then. Thanks for any input and suggestions.....peace.
I missed the part where the ignition and run are off. I agree with Joe. Corrosion at a connector or a short in a wire
Power is supplied to the IAC when power is shut off. It is applied long enough to park it. If it is having problems getting to it's parked position it will keep trying. Several reasons this can happen. Checking corrosion on pins and connectors, and clean the IAC is where I would start because it can all be done for free.
I am under the understanding that the ECM sends the command after shut down, and if the ECM doesn't think that the command was received. It will keep trying. It does this as a reference to know where the IAC position is, so it can put it where it needs to be for the start IAC position.
