CKP Sensor part number for Sporster 48 2015
Hi,
I just got back from a 1200 mile trip and it seems that for some reason my CKP sensor is failing. I am getting the occasional p0374 check engine code which is for a faulty CKP sensor. I looked around the forums and I have the same issue as people who have had problems with the same sensor:
Heck, I am not even sure if I can get some sort of generic sensor. I was thinking of getting two since people say these sensors fail quite constantly.
Thanks
- Idle RPMs drop to the point of almost turning off the bike.
- Lots of backfiring, but only sometimes (when bike reaches certain temperature).
- Engine seems to be struggling for air.
Thanks
Hi Rebel, the issue was not actually the CKP. It ended up being the MAP sensor. However, the MAP sensor was working correctly, the problem is that one of the cables (near the sensor) seems to have broken.
You can check this by basically using your hands to move the cables near the MAP sensor. Keep in mind that it takes a few seconds for the motorcycle to actually "notice" that the cable is connected or disconnected, so it is a bit frustrating to find. If you wiggle the cable a bit and the sensor gets marked with a check engine that is your likely culprit.
You can get a replacement connector and cable from BMotorsports.com and I got the GM Delphi / Packard - 4 way metripack 150.2 sealed male connector Pigtail for iac, black. About 11 USD shipped.
Another issue I had was that another cable was also pinched from my cobra power module (sort of like a power commander). So I basically cut the pinched wire and soldered on a new wire. After I did all of this the errors went away, but the main culprit was definitely that pinched cable near the MAP sensor. By the way, even though the cable was pinched, from the outside the cable looked intact.
Hope this helps!
Hope this helps!
rebel7 (05-29-2018)
Thank you for the reply Nickvda, I'm going to definitely check this out. I replaced the CKP but I had the issue pop up again after a long ride. I have to think that it has something to do with the harness since the symptoms only appear when the bike gets hot. Most likely a wire fatiguing.
Unfortunately I had the same thing happening with the main wiring harness due to a broken wire in the fuel injector connector so I am pretty sure that this is related. I'm almost half tempted to buy a new harness at this point before another wire breaks.
