New HD Tune Strategy question
HD recently released a new tune for the 14-17 Dyna/softail 110 motors to address hard starting. This modifies the ACR operation. It's called Strategy 621, vs. the prior tune version, 617.
Got the download yesterday from my dealer, and am well aware that it wiped my existing excellent tune from FuelMoto. My question is if I were to copy over all the FuelMoto modified tables - airflow, fuel, spark, etc., to the new HD 621 tune, is that all I need to do? I know the ACR area that was fixed isn't visible to the WinPV software, but to correct the overly lean EPA tune, is that all I need to do?
WinPV has a nice delta function that shows all the tables with differences, so it's as easy as copying and pasting each.
Jamie at FuelMoto said he would apply my tune to the new HD Strategy, but I want to ride this weekend and not on the factory HD tune, so if it's as simple as I said, I can do that myself.
But I want to make sure it is indeed that simple.
Most ppl in this forum have a lot more experience with this then I do, so before I go ahead and upload the hybrid tune I just made, I wanted to check.
Thanks.
Thanks.
So I was hoping there were other lunatics like myself up this early. Apparently I was correct
Definitely have to keep tabs on those telecomm guys, especially w/end equipment + links. Our fiber crew patched into wrong ports a few weeks back, but swore they tested continuity...they were wrong (liars) and I called them out. Been doing IT work since 1988 so I have a "little" knowledge in my cranium.
I'm hoping to hear back from dealer today on this flash/update for our 110's...had the hard start/fail last Sat & they plan to assess later, but would be nice to get the flash and test our before 1K service.
Hope the weather's better there than here, my friend...48-degrees and wet in Eastern NE. Ride safe!
Show them this:
Title: M1445: PRODUCT PROGRAM 0924 - 2014-2017 CVO SOFTTAIL/DYNA 110 CALIBRATION REFLASH
Global Reference: M1445_1063265_en_US
Navigation Path: Vehicle -> Service Bulletins
Publication Date: 04-May-2017 19:37:24
Edit: Maybe this should be in the Dyno Room forum? Mods, what do you think?
Talk about impatience. I need to ride today. So I flashed the modified new 621 tune and started it. Heard the new "click" of the ACR's opening when I switched on, and it started up nicely. I didn't run it at all, just started, idled, no check engine lights or anything abnormal, and shut it down.
I'm hoping someone with real tuner experience like Wide Open Cycles, gives me the "OK" that I did it right, as I really want to ride today with a clear conscience...
Mchad (05-20-2017)
I'm not sure what all tables Jamie modifies, some will be exposed to you and some will be hidden tables that few of us have access to. You should be fine to just copy/paste the tables Jamie modified. Especially the VE and the ignition tables. That should get you by just fine for the weekend but I would definitely take Jamie up on his offer to apply the changes to your new Calibration
Take care
