Finally got my bike dyno'ed, and it wasn't what I expected
Bike is a 2015 street glide with Fuel Moto 107 kit. 10.5:1 pistons, 999-6a cams, level B heads, D&D Fat cat exhaust, and a Power Vision with autotune. I am running the tune from Fuel Moto with a couple of auto tune sessions. The bike runs strong and is fun as hell to ride.
The dyno run was done at my local HD on a Dynojet dyno. They wouldn't let me in the back to watch, but I assume it was done in 6th gear.
My numbers were 106hp/ 112tq. This is 13hp/ 13 tq lower then I was expecting based on an identical setup on Fuel Motos site.
A couple questions
1 Can the difference in power just be the difference between dynos?
2 Why is the torque curve so different between the charts?
3 Any problems/ issues to check for?
Fwiw my buddies 2015 RGU CVO with SE cams, intake and true dual exhaust did 97/107 on the same dyno.
A couple questions
From what you posted it sounds like your bike had a dyno test, the FM bike was dyno tuned.... big difference. On your dyno run nothing was done to optimize the tune.
You need to go somewhere where they will make the needed adjustments.... dealers are very reluctant to do that.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
You mean the numbers were not as advertised by the seller of the kit that he got on his own dyno? That is why I always look for 3rd party dyno numbers and it helps to get a couple of different ones from around different part of the country. If the seller's is always the highest. Red flag.
oleboy (05-18-2017)
The first thing I noticed is the correction factor is different. SAE vs STD. That will yield different results. Also I couldn't tell what gear the FM dyno was tested in. There could be a significant difference there also. 5th vs 6th gear. Your Dyno was done in 5th gear, look in upper right hand corner, is reads "smoothing 5". As long it runs good and no de-cel pop and the AFR is in spec you should be good to go! I would recommend letting a good tuner get ahold of your bike so they can optimize what you have. I have a "canned" tune from FM in my Road Glide and it needs some massaging. Dyno and tune is scheduled next week for mine.
FLTRI17 (03-25-2022)
