Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 2000 FLHTCI wanting to put a stage 1 air box on and a duel exhaust not sure what tuner to get? what do you think
You have an M & M fuel injected bike.
A consideration would be to contact Fuel Moto for a power commander.
They well send it to you with a down load installed for your application
yup. if you want a crisp running bike. I had a Vance and Hines tuner(garbage) and switched to a PV. what a difference. Throttle response was night and day. Then i added a high flow ac and a 2 into 1 exhaust and it was even better. next is a cam over the winter.
For a MM, a powercommander with a dual cylinder map is the best way to go in my opinion. When the tuner has Tuning Link, the map process is a lot quicker and less stressful on the bike.
