07 Harley Davidson street glide crank but no start, Help!
Hi guys, maybe someone can help me, I purchase a 2007 Harley street glide that was laid down (got in accident) and sat for a few months. Nothing major just the front fairing was cracked and a few scrapes on the bags and engine guard.
i Put it back together, and it cranks, i got fuel but no spark, I can hear the fuel pump and when I disconnect the fuel line it even squirts fuel really good. I hooked up a coil tester, you know the kind with the light bulb that lights up as it gets current, but nothing, I'm NOT getting any spark. All fuses are good, and the motorcycle has a Dyno-Jet power commander 3, that I notice it doesn't lights up. Is it suppose to light up? Looks like there's led lights in the power commander module..
Also I read something about a "tilt sensor" could it be that? And where is it located..?
I need help pls.. 😕
I need help pls.. 😕
Hey winH, from whay I been reading, and from what a technician told me, your problem is gonna be the "crank position sensor" check that, also the connections..
Best luck 😉
WEll.....I'll try to help....one thing is the tilt sensor.....or Bank Angle Sensor....not sure if you have it or not......it's in the switch housing in the handlebars.......cycle ignition switch off and on a few times, that resets it if you have it.
Also......if there is no compression seen by the computer it won't fire......so if you have both plugs out....it doesn't see compression and no spark..ION sensing issue there...put one back in.....then try the spark test against motor.
Thx you Murph, I Will try that 😀
