having some issues with my 13 streetbob
I was leaving the gas station last week after about an hour ride. when I pulled out onto the main road and hit the throttle it fell on its face and wouldn't rev any higher than an idle without wanting to shut off. I limped it home and started going over the bike. nothing seamed out except the headlight was out. checked the codes and got
map sensor fail open/low
5v+Vref 1 out of range
accessory output shorted low
starter output open/bcm malfunction
starter output overload
high beam output shorted low
lowbeam output shorted low
running lights output open
bcm voltage low
I took the battery (that I just bought the day before) back and they tested it as a bad battery and gave me a new one. put the new battery in and it won't start now.
any ideas before I go get reamed at the local Harley shop?
bcm voltage low
