Bike died, left with intermittent buzz
Old 09-11-2017, 01:39 PM
IGottaRide's Avatar
IGottaRide
IGottaRide is offline
Stage III
Default Bike died, left with intermittent buzz
Ok, so I took my 2005 883 sportster custom to the store. Later when I turned on the ignition switch the bike turned on, just for a split second and everything went out. I played with the key (on and off) for a couple minutes but nothing came on. Then I noticed that there was an intermittent buzz coming from the speedometer. I trailered the bike home and the next day I noticed that the buzz was still there; with or without the key. At this point I disconnected the battery. There's not much more to say. It had been starting and running fine, no problems at all, before this.
Old 09-11-2017, 05:13 PM
roussfam's Avatar
roussfam
roussfam is offline
Received 6,709 Likes on 3,489 Posts
Congrats on your first post and welcome to the Forum
Old 09-12-2017, 04:47 PM
larsfum's Avatar
larsfum
larsfum is offline
Sounds like something is shorting to ground. Tough to diagnose from what you have posted. Try to isolate where the buzz is coming from. First ting is to check your battery cables at both ends. That they are tight, and clean. Next would be fuses, and main circuit beaker, then relays.
Old 09-12-2017, 09:45 PM
bustert's Avatar
bustert
bustert is offline
maybe the master relay is bad
Old 09-13-2017, 07:09 AM
IGottaRide's Avatar
IGottaRide
Stage III
Yeh, a blown fuse was the first thing that came to my mind but when I started to hear the buzzing I figured that it's got to be something else. I won't get another chance to look at it until the weekend but I'll check the fuses and relays. Thanks
Old 09-25-2017, 07:00 AM
IGottaRide's Avatar
IGottaRide
Stage III
Finally got a chance to look at the bike, this weekend. My son said to start by checking ALL the fuses, not just the ignition. Well, as much as it hurts to say it; he was right. I pulled each fuse, one at a time and sure enough, it's running fine.
Shane87609
07-12-2018 11:45 AM
Kathiesdude
05-10-2018 05:33 PM
DHolliy
08-02-2016 01:18 PM
NefariouSaul
02-19-2016 09:35 AM
lucospock
10-24-2006 07:23 PM
Quick Reply: Bike died, left with intermittent buzz
