Help! New to HD, want to increase MPG.
Calculate your MPG, then tell us what it is.
A) Fill the tank all the way, and record the odometer reading.
B) Run it until the light comes on.
C) Fill it up to the same level as before, and record the mileage, and the gallons (including fractions) put in.
Subtract the mileage in C from mileage in A, then divide by gallons put in. The result is MPG.
most canned tunes are pretty rich. I also have a 3.3 gal tank and have my bike tuned very well. On the highway I can 90-100 miles before the light comes on and I have about a gallon of fuel left at that point.
All city and I can go about 70 before the light.
Thats about 35 mpg city 45-50 on the highway.
Right, let's go back to basics! You fill your tank, then ride your bike until the light comes on, and refill. After just two refills you now know how many miles you have ridden and how much you have left in your tank, when the light comes on. As suggested already, work out your mpg and you can estimate how far you can ride on your reserve, until you REALLY need to refill!
You can probably safely ride another 40 miles after your light comes on. Nothing has changed since the very first motor vehicle with an engine was built, over a century ago, so don't make a crisis out of the normal. In the past when we only had carbs, you would run out of gas, fumble around for the reserve position of the gas tap and hope the engine lit back up. Plus ça change!
It's a fact of life that we have to fill up each vehicle we own as it uses up its fuel. Not a difficult thing to grasp!
