Dyno and powervision
HEY GUYS, I have a Powervision, and a Target Tune, il get a start up map from Jamie, or dynojet, who ever available at that time, question is, last year with the few auto tune sessions, above the tune given to me, seemed great, ran a tad hot, but its a 107, no oil cooler, upgraded pump, so thats ON ME,theres a guy who will dyno, he said it take 6 hours or so, all day, maybe he lets cool down and goes back? Will it benefit me to do this? Or just run the auto-tune sessions, and be fine, like I said I was happy with the 107...this is going to be SS 110 drop in stage 3 or 4 Hillside heads....so he can dyno tune, and have it programmed into my power vision, and target tune, will work to keep it there, is this the best option, for 600 just want to make sure its worth it, I have others who will dent for half, thats more to get a better tune, and a "Brag Sheet" which guy should I go with, and why?????
Just keep in mind street tuning may or may not provide a great running bike depending on a lot of variables.
The absolute best way to do performance enhancements is to at least have a dyno to quantify and evaluate the mods and the performance comparisons to same and other builds.
Just because a box of parts and a “best guess” base map gets installed on a bike, unless a dyno is used to at least check performance, there is nothing but guessing as to how a build/mod produces.
At a minimum I suggest a dyno run to evaluate the results from your street tuning. Many times folks spend the money for the performance but never realize the increases due to lack of precise recalibration of the fueling for that particular bike and its idiosyncrasies that generate need for custom calibration for every bike....unless less-than-optimum performance is acceptable.
Bob
Bob
TOMMYBLAZIN (01-02-2018)
Bob
Bob
I hear so much, the one guy recommended, wants a DAY to dyno and 699!! seems very excessive, and if its only a few HP more from what I have, ill never feel it, that Powervision, and Target Tune, I dont think gets the credit it deserves, that Closed loop system, is : REAL TIME" And it keeps bike in safe running parameters, like the dyno, with closed loop and some auto tune sessions, the target tune, will get it there, and im sure theres, so SIMILAR universal TUNE they shoot for, which I believe my tuners are programmed to do, unless im wrong?
and no I dont want to settle, but if it's WORTH IT....YOU KNOW??
ahh
CONFUSED!!!!
ahh
CONFUSED!!!!
hrdtail78 (01-04-2018)
I'm not sure, I'm coming from a fp3, thats why I'm looking for advice,if my power vision/target tune, will benefit, than ill do, but what about weather changes etc, how does that come into play, when It comes to tuning, I'm a student, at best.
The PowerVision system does not add timing in it's auto-tuning....in some cases(if you're lucky) it can retard some if the parameters are correct and you have the spark timing function enabled during auto tune. I have not had good luck with this function,,,,,proper timing is essential for optimum performance, and in my opinion, the only way to set it up well is on the dyno. I would suggest that you get the bike tuned by a reputable tuner with a good track records of proven results, after all you did just drop a large chunk of cheese to get it together, do it right and finish the job so that you can get maximum results for yur money. A proper tune can take a fair amount of time, depending on equipment and conditions,,,,,to me 4-6 hours is not an unreasonable time involved for someone that is truly tuning the bike,,,,fueling, timing and road test confirmations.
marco
marco
ahh
CONFUSED!!!!
ahh
CONFUSED!!!!
Real time closed loop has come on stock HD's since 2006. Tuning will do so much more than just showing an increase in HP at WOT. If people think that is what a dyno tune is all about. They are missing the point of the other 90% of the VE table. Sounds to me you bought into the BS advertising, and spent extra money of dumbing down the stock HD Delphi system.
