A Honest Question.
For the level of mods that you are looking at doing. A flash based tuner is you best bet. The aftermarket is way too focused on air/fuel when in reality that isn't half of what needs to be done to get a bike in a good state of tune.
Load based timing tables and the stock spark retard is much easier for most to deal with over TPS timing tables and no feedback.
Flash based = like pv? Re-wrights the ECU?
Which is a better system for timing and spark? Can you recommend a product?
My mods are a new engine, heads, throttle body, cam 10.25:1 103 in a 2005 softail
I have a pc3 but am thinking if I get no joy with tuning I may upgrade, probably something with a auto tune. I don't have 02 sensors but can fit some.
I just want a reliable well tuned bike.
Thank you.
Not it sure what you mean. A good tuner is only as good as the canned map you load on it. If your mods are simple like exhaust and AC then no need to get professional dyno tune. PV, TTS, Thundermax, FP3 will all work just fine with a canned map with similar mods. When you add cams, head work, throttle body, injectors, higher compression, etc you want to get it professionally tuned to maximize the potential of your build. Sure you can auto tune, but you would be leaving a lot on the table especially if you are using the stock narrowband sensors.
Hi, I'm interested in this also. Can you clarify what you said?
Thank you.
Thank you.
A flash based tuner rewrites the stock ECM. This is compared to piggy back systems that don't change the ECM but change the signals coming out of the ECM. Tmax is what I consider a stand alone unit. You do flash it but only with Tmax.
Flash based is what I prefer for 99% of the tunes I do. TTS IMO is the best tuner with the most useful features. It actually address the timing side of tuning like no other tuner on the market. There aren't codes to unlock this feature or that feature. Everybody get the same with TTS. With one data collection run. TTS address's wide band and narrow band VE mapping, Main spark table and spark temp correction, and EGR tables. The rest of them will address wide band and narrow band but not at same time. As for as the other feature of spark and EGR (CDE.) Plenty of threads to read about how they are lacking.
With an 05. You have no o2 feedback. You can buy all the equipment, learn how to tune, and spend the time doing so. Or you can spend the same amount of money. Pay a tuner and have a tuned bike with very little work on your part. Depends if you want to spend time learning and tuning or riding.
That is kinda of what I do not want to do is put my bike on a dynometer. And pay that extra price for a one time tune. I am not looking to squeeze every last piece of horse power out of my ride. That is what a good tuner is supposed to do without going to a dyno tune. Right? I just want decent performance and good MPG. Powervision is looking like what of the majority of the riding population is going with. And. What my "indie" shop is recommended. Although they used to use Thundermax 90% of the time. Que Sera,Sera,
Lol, sorry about that, I went back and fixed all the typos. The auto correct on this phone gets me all the time. You'd think I'd learn to proof read before posting.
harleytuner. Can the TTSMastertune be used without O2 sensors. The reason I ask is that my 07Ultra came with O2 sensors but the previous owner replaced the header pipes with ones that do not have O2 bungs. It is no problem for me to add the bungs. 18mm wide bands? The connectors are still there. Thanks.
