A Honest Question.
There's benefits to both types of sensors. If you want to do it the best way you would do both, get the TTS with the analog inputs, get wide bands and tune with it. Then when you are done remove the wide bands and replace with the stock narrow bands and run the bike in closed loop.
With what you have and what the options are out there. To set up your bike to tune yourself. You are looking at an investment. Time and money. I would also suggest looking into Nick down at Shamrock Cycles in Austin, or GMR up in Fort Worth. Both use TTS. I know Nick uses analog inputs with his TTS tunes and I am pretty sure Steve at GMR does as well.
Nice thing about this is. They will sell you a regular TTS for downloading, and use their shop TTS with analog inputs for collecting data. Plus no learning on your part. When they are done. All you have to do is ride it.
He mentioned he didnt want to get it tuned on a dyno but rather get a ECM tuner where he can get decent performance and good mpg. I think when he sees the overall cost of the TTS and the with wideband sensors and the work that it takes to learn and get it up to par, he might just take your advice and see one of the recommended shops.
Taking it to a shop is definitely the advice I would give, but the OP stated early on that he's wanting to do it himself, which is what I was basing my recommendations off of.
Steel Steed
19
04-27-2016 06:59 AM
