New Battery, Bike won't even turn over
I just replaced the battery on my 2012 Harley Electra Glide. I turned it on, but have no indications of power. When I turned it to the ACC position, my radio came on, but I show no power indication on my display. The Multimeter reads 12.5 V. Not sure what I might have done wrong. I've watched videos and followed them to the T, but still lost on the problem.
Scooot72 (02-22-2018)
Progress so far
@ wadejesu, there is only one thickly bundled cable attached to the + side, I even pulled the battery out to make sure I didn’t set the battery on it when installing the new one. @ memphissharley, the old battery had 10.5V on it before I turned it in for the core refund with the new battery. I was able to start the bike with it with attached to my vehicle battery, but was unable to restart it again after shutting it down. I even let the bike run a few minutes before shutting it down.@ perki48, I checked the kill switch, it was on. I was the only one to touch it, so I would be at fault if I hit it.Anyways, after I got home from work this morning, I checked a few thing. I rechecked all the fuses and everything was good. I looked for a shorted cables and didn’t find any. My connection to the battery was clean. I even pulled the battery out to look for any problems in the battery seat. After reinstalling the battery, I decided to just attached my vehicle battery to the bike battery. I kept my vehicle off to minimize fluctuations in the amperage. Everything lit up on my display in the ignition setting. So, even though the new battery read 12.5 V, the amperage was probably too much for it when it was hooked to the load. I took the battery out and hooked it to a charger to give it the full charge. I will put it back in the bike, probably tomorrow, and let you all know if I succeeded or if I was sold a defective battery (that would suck). Thanks for all your suggestions so far, they help me think better.
perki48 (02-22-2018)
