FP3 autotune question.
I have a 2016 RGS and I was trying some auto tuning yesterday and got some good results.I hit the apply changes after I was done.So later that day I wanted to do another autotune and noticed a third map was loaded.I have the stock harley map.The map I picked a year ago and one now says autotune.Before I started the first autotune session It had me pick the map I wanted to autotune so I picked the map I’ve been running for a year.And I have hit the finished button to apply the changes.I want to autotune today and it wants me to choose a map. I’m thinking I should choose the autotune map to keep building on it???
Or should I start over and hit the finish button when I’m truly finished??
Thank you in advance.
You need to hit apply not finish, that is your issue. Once you hit apply the cells will all turn white again, but the previous tune will all be saved. It will only add to your tune, not take away. More time, more runs = better tune.
Finish will close out your session and new data will not be saved over it.
Idahokid (04-22-2018)
With the FP3, each "Finished" Autotune session can only change certain parameters of your tune by up to 10%, no matter how many times you hit "Apply" during the session. So while hitting apply during the session does apply the learned values, if your tune needs more then the 10% adjustment in those areas, "Finishing" and starting a new session is the only way it will be achieved.
If the required change to the tune is greater than this then you need to run the autotune process at least a second time to see if any further change is required.
As with all autotune variants across all of the different tuners, you basically keep at it until changes are down to a couple of percent or so, then, that is as good as you are going to get it without chasing your tail forever.
The FP3 is not very good at telling you how much the VE cells have changes so you kind of don't really have a clue how tight the tune is ...without manually comparing two saved slots (i.e. finished tunes). Vance and Hines basically cheats, by telling you to do at least 3 autotune thingies ...which should be good enough (cough)
Apply - ends one single autotune thingy, overwrites the starting VE tables in the memory of the autotune process with any learned cells so far, resets the learned data table and clears the hits screen ...but leaves the FP3 in autotune mode and starts a second autotune thingy
Finish - does exactly the same thing, except, it makes a new tune and asks you which slot you want to save it in (you can overwrite any of the slots except slot 0 ...so overwrite the oldest one if there are no free ones left). It then exits autotune mode and flashes the new map into the EFI.
Sam D. (05-16-2018)
