2001 Ultra classic, Starts then dies
Old 06-16-2018, 08:49 PM
RPPrince12pk's Avatar
RPPrince12pk
RPPrince12pk is offline
3rd Gear
Default 2001 Ultra classic, Starts then dies
My 2001 Ultra starts right up then after a few seconds begins to miss then dies....hit the start button and it lights right up again and does the same thing....Ive replaced the engine temp sensor, the gas lines inside the tank (pinhole in the pump to filter line...thought that was the problem originally) changed the fuel filter....pump cycles so I left it alone...changed out the fuel check valve and line to the pump as well....Im running out of patience chasing this ghost...I really dont want to get into the ordeal of throwing parts at it.....Im also not getting any codes...I suppose its time to get someone to plug a scanalyzer into it to get me pointed in the right direction...any ideas?
Old 06-16-2018, 09:59 PM
mmesa005's Avatar
mmesa005
mmesa005 is offline
When I owned a 2001 Electra Glide with Magnetti Marelli EFI I would have to go through and set up the cold idle otherwise it would behave as you described.
https://www.hdforums.com/forum/ignit...li-mm-efi.html
https://www.cvoharley.com/smf/index.php?topic=36493.0
RPPrince12pk (06-19-2018)
Old 06-17-2018, 09:39 PM
ruger12pk's Avatar
ruger12pk
ruger12pk is offline
Stage I
I agree with that, however in my case, and I failed to mention it beforehand, but I have an S&S throttle body setup on mine....
Old 06-28-2018, 09:40 AM
Zateeva's Avatar
Zateeva
Zateeva is offline
my sportster was doing the same thing, problem on mine was the bank angle sensor, it kept thinking it fell over, not sure if you have one on that bike tho
Old 06-29-2018, 06:32 AM
RPPrince12pk
3rd Gear
I think it does....its on my short list of crappy HD sensors to fix or replace.....
Old 06-29-2018, 08:41 AM
larsfum's Avatar
larsfum
larsfum is offline
Did it just start to do this? Have you performed any recent work on the bike? The early twin cams had a problem with the front injector pigtail being too short. It would stress over time, and break inside the insulation. You can try a wiggle test to see if that is the problem. Also I do not see an S&S throttle body that says 2001 in the current catalog. Do you know what size it is, and which injectors you have in your bike, green or red?
Old 06-29-2018, 10:41 AM
im's Avatar
im
im is offline
It is reading as fuel related.
What happens if you hold throttle while cranking and maintain throttle?
No mention of history prior to problem, unknown miles ?
It would seem like you might have some other throttle body set-up that is not factory original and it is unknown if it is related to present problem or if that part was working before.
Reads as fuel related...does bike run if throttle is maintained?
If so, then review the idle control actuator or linkage to it.
Mtrumpe64
EVO
17
05-08-2020 08:59 AM
Mtrumpe64
Engine Mechanical Topics
06-25-2019 10:58 AM
Mtrumpe64
06-24-2019 10:10 AM
Gmtapke
10-02-2018 10:11 PM
schuffyman
09-25-2015 12:26 AM
Quick Reply: 2001 Ultra classic, Starts then dies
