Are there any automotive cross overs for S&S fuel pressure regulators?
I have a 2001 Ultra classic I bought a few years ago that has an S&S throttle body on it....Looks like I'm needing a fuel pressure regulator so Ive put in a request for info to S&S proper but, Id like to find out if there is any automotive cross overs for that part...the only number I can find on the FPR is as follows; 95c, 4.0b, 1358...any ideas?
UPDATE......S&S guy tells me, "Sorry we don't sell those...try aftermarket parts catalog"......really? No details on it like number or any sort of sourcing reference...
well anything is possible. direct fit, probably not, but not all is lost. with your tom terrific hat you can install an automotive one with adjustable set point.
jegs and summit racing are good outlets. when my inline tank pump quits i will install external pumps on the frame rail closest to the tank as possible since they are designed to push and not pull, fraction of the cost of original and no more dropping tank.
It's just a 4 Bar Harley regulator #27408-01 from a 2002 - 2007 Delphi equipped touring bike. Magnetti Marelli were same physical dimensions but 3 Bar. In 2008 they started selling it as a kit with a spacer but I believe it's the same regulator.
This should be easily obtained from Harley or S&S. Here is a pic of one from a Delphi equipped Harley.
and here are S&S listings. OR you can google 4 bar pressure regulator and you will see a lot of them.
For quick guaranteed fit just buy the Harley one - it's only a touch over $30.00 at online dealers (probably about 38 at a brick & mortar dealer) and guaranteed to fit and work.
https://www.sscycle.com/docs/default-source/instruction-sheets/51-1239-single-bore-tb-1995-05-20151229.pdf?sfvrsn=4
https://rssd.cld.bz/Manufacturer-Catalogues/S-S-Cycle-Dealer-Catalogue/290
RPPrince12pk (06-23-2018)
RPPrince12pk
06-23-2018 04:21 PM
KevinKruuz
07-29-2012 07:12 PM
