2014 Dyna Misfire
As hard as it is to diagnose a running problem over the internet, providing as little information as possible only makes it more difficult. Stuff like mileage, mods, recent work done and anything else you can think of to describe how and when the problem happens will help to figure it out.
Meat on the bone
More info on the misfire between 2000 and 3000 rpm. 2014 103cu stock motor. 3" slip on V&H, std baffles, high flow air intake. FP3 fuelpack. Not convinced it's an ignition problem as revs perfectly all the way up in 4th 5th and 6th gears. Have tried multiple different maps using the FP3, have also ridden 250 miles in Autotune. More info, have managed to reduce but not eliminate the problem by editing the Air/Fuel table to make it slightly richer at the bottom end of the MAP range, between 2 & 3K RPM.
