2013 Street Glide misfire HELP!!!!!
read up on how to reset your throttle. there is a sequence for turning the bike on and off, but i don't remember it exactly off the top of my head. it will reset the throttle position sensor so that the bike knows what is idle and what is not, i've heard of similar complaints as yours and this was what it actually was. some people shut the bike off with their hand still on the throttle, keeping it partially open, and some have it partially open at start up, this kinda whacks the ecm and throttle module out so it doesn't know where to start from.
also might remove and clean and grease the harness connector at the throttle module.
m
m
With run stop set to run.
Ignition on for 30 seconds then off for 30.
Repeat 2 more times.
Sorry it took so long for me to get back guys but I found the problem. Let’s just say that I’ve changed out ignition coil with no luck and the only thing I had left was crankshaft position sensor to replace. So this weekend me and a buddy were scratching our head and he said have you changed the plug out with a old plug just to see? I sad why hell no we put the new ones from Harley in before we left for bike week and guess what put a old plug in and boom she runs like new. I have never felt so stupid in my life but hey all I can say is if you are having a back cylinder not firing issue CHANGE YOUR PLUGS OUT BEFORE YOU DO ANYTHING EVEN IF THEY WERE NEW!!!!!!!!!!
djpullen
09-11-2010 05:41 PM
