What is the output of a 2000 Twin Cam throttle position sensor?
From the manual: The TPS is supplied 5 volts from the ECM (5v REF) and sends a signal back to the ECM (TP Sensor Signal) which varies according to the throttle position. The output signal from the TP Sensor varies from 0.40 - 0.60 volts at idle (closed throttle) to 4.6 - 4.9 volts at wide open throttle. A code 11 will set of the TP Sensor signal voltage does not fall within the acceptable range.
The TPS sensor is a potentiometer, providing a variable resistance depending on the position of the throttle valve (and hence throttle position sensor). Note the drawing from the manual and symbol for fixed resitor.
Cobra1 (08-13-2018)
WOS Bishop
08-22-2011 11:38 AM
