Has anyone just pulled their Fuel Injection?
Old 10-05-2018, 12:31 PM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
Originally Posted by donk_316
Ignorance? Lol
A carb is LITERALLY a controlled fuel leak...
are not injectors prone to leaking?
its all in fun..
but don't bash a carb,
They are way more reliable then F.I.
Old 10-05-2018, 01:54 PM
Wizardofaus's Avatar
Wizardofaus
Wizardofaus is offline
What possible advantage could there be going from a computer controlled fueling system to a "Controlled fuel leak" carburetor system?
None.
Zero.
Zip.
Well I can think of a few advantages of a carb fueled bike
No need for A:-
High pressure fuel pump
Injectors
Map sensor
Oxygen sensors
ECM Computer
Ya gotta face it Carbs are cheaper to maintain and rebuild , and if ya motor needs extra juice It’s just as simple as a bigger jet or a needle clip change up.
Wiz 🍺
The following 2 users liked this post by Wizardofaus:
Kingglide549 (10-05-2018), Lakerat (10-05-2018)
Old 10-09-2018, 11:38 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
FWIW, If I lived in the bush I would own carbed everything..cars, trucks, bikes, generators, etc.
Other than that I prefer the preciseness, response, and mileage I get from properly tuned efi bikes.
Bob
Old 10-09-2018, 11:40 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,540 Likes on 3,792 Posts
It's advantage is left stock, the cylinders will never wear out. Even the first generation MM, when understood, is better then a carb.
Dan89FLSTC (08-19-2019)
Old 08-19-2019, 10:26 AM
evotrike's Avatar
evotrike
evotrike is offline
Carb conversions are for deep pockets. I like my MM. Would like better mileage, but run a trike kit, 2 up,with 23 lbs. air in rear tires for smooth riding . Gets the job done. Ken
Old 08-19-2019, 11:09 AM
Wizardofaus
What kind of trike kit do you have.
A picture of the bike would be nice 👌
Wiz 🍻
Old 08-19-2019, 11:38 AM
K9F's Avatar
K9F
K9F is offline
Mate of mine rolled back to carburettor on his 2014 Forty-Eight. Cost him ballpark £2000 to achieve it and initially had running issues and waterlogging in wet weather due to moisture getting in the intake.
Old 08-19-2019, 01:12 PM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
The first carb was in fact, a somewhat metered fuel leak into the intake.
The latest carb design is in fact, a well developed fuel leak.
It is for this reason , as well as others, we have EFI...to get rid of the fuel leak...which produces more power with less fuel and emissions.
Bob
PS- As I’ve stated, if I were to be regularly out riding where there is no availability to current EFI replacement parts, I would have a carb for sure.
Old 08-19-2019, 03:09 PM
evotrike's Avatar
evotrike
evotrike is offline
Wiz 🍻
Here ya go, Wiz.. '98 Ultra with Champion solid axle kit.
Wizardofaus (08-20-2019)
Old 08-20-2019, 08:46 PM
stroked83fxrs's Avatar
stroked83fxrs
stroked83fxrs is offline
Stage IV
My first gen FI is a piece of trash.... unless it is not being maintained right.... the problem is what does one do to maintain an FI system?
Quick Reply: Has anyone just pulled their Fuel Injection?
