1998 Ultra classic Electra Glide 1340 not charging.
Hello,
I have a 1998 Ultra classic electra glide with a charging problem. Bike volt meter started go to 10 then 8 volts and shut of. So I replaced the 5yr old battery to start out fresh. After fully charging battery I used my multi meter and battery read 12.7V. Started the bike and checked battery and there was no charging happening. So I pulled the plug on the stater and at an idol I had 20volts and as the reved the bike higher it went up to 40. So I assumed it was a bad regulator. I cleaned all the connections and replaced the regulator. Started the bike and had the same result. No charging. Any suggestions?
Hi from the UK and welcome to HDF. Go to the Tech Electrical section, where you will find a couple of Stickies describing in more detail how to check your charging system. They should help you identify the culprit. You can also visit the Evo section, to meet up with fellow Evo owners, where Dr Hess has written another Sticky.
whitlow
Electrical/Lighting/Alarm
10-12-2016 07:06 PM
