Need some PV guru help
On a trip in Gatlinburg, bike started running weird, like it was surging and bike getting hot pretty quick. Only happens when the bike is held in 2 or 3rd gear and a constant rpm for a few minutes. Was running autolite plugs, got a spare set of HD plugs and bike started faster and seemed to run a bit better. Surging didn't go away though.
Checked the PV and no codes. Checked while the bike was running and found wheat I think is weird o2 readings,
VE front 67%
VE rear 76%
Volts front 2.34
Volts rear 4.32
o2 ratio front 14.3
O2 rear 16.7
Lambda front .979
Lambda rear 1.14
Checked autotune wiring, all looks good, connectors at sensors not corroded.
09 street glide
103 jugs
SE203 came FM as
Jackpot pipe and 4" muffler
Powervision and autozone pro
Map from FM
VE front 67%
VE rear 76%
Volts front 2.34
Volts rear 4.32
o2 ratio front 14.3
O2 rear 16.7
Lambda front .979
Lambda rear 1.14
09 street glide
103 jugs
SE203 came FM as
Map from FM
On a trip so changing the sensors isn't ideal....but I was just reading through the PV thread and came across another guy that was having similar issues, which may have been from reversion. Gonna try to treat that possibility in the morning. If they is the problem I'll have to call Jamie & Co. To see what to do.
thanks for the suggestions,please keep em coming.
