Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I've done that. Pulled headlight and tank, checked all connections. Also checked juice at kill switch and coil, has power where ever the bars are.
The engine is either killed because one of the wires to the kill switch is defective, or another wire is grounding. If you have recently wired new bars internally, then check electrical continuity over each wire. Don't be surprised if you have to strip the lot and inspect, retracing your steps right back to the start.
