Thundermax and Power Vision
I'm currently running thundermax ecm with Autotune and their o2 sensors. I have recently bought Powervision to have the display and to change maps without dragging my laptop every where. So my question is, can I leave my thundermax equipment on and run the PV or do I put my stock ecm back in and stock o2 and just get rid of the thundermax equipment. 2011 Dyna FXDb
The powervision unit will only work with the stock ecm. put the stock stuff back in. if you feel the need in the future, you can weld in bungs for the wideband sensors, install the sensors along with the stock, and wire in an autune module, this would give you wideband tuning capability, and be used with the display. if you dont feel the need for the wideband data, you can skip that part, as I mention it just to let you know that it is possible to do.
m
m
DynatrashJohnny (12-07-2018)
This is right where I am now . I'm thinking of pulling the Tmax off my bike and making the switch to PV .
Problem is the shop that did the Tmax set up 4 years ago left the O2 sensors in my original pipes when they took them off , and I never thought to get them back . I still have the original ECM , so will I need stock oxygen sensors for an 06 to use the PV ??
Scott
Scott
yank721 (07-27-2021)
Scott
Scott
WDinFallCity
07-05-2012 11:34 AM
