Stalling, bad idle, hard restart.
Old 01-17-2019, 05:51 PM
petebob's Avatar
petebob
petebob is offline
Originally Posted by springers4ever
what you describe in the first post ...kinda sounds like a head temperature sensor could be acting up ....
this would cause the ecm to add warm up fuel when the motor is hot already ....making it too rich ..causing the low idle ...
or a loose connection at the sensor itself ...
ETS (head temp) sensor was replaced. Have also fitted a new battery. Bike hasn't been ridden for a couple of weeks, but will update when I can.
Old 01-17-2019, 06:07 PM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
pull on the wires where they go to the ETS connector - see if it is broken inside the insulation at the connector. Code for ETS fault doesn't mean sensor is bad - means circuit has a problem - sensor is part of circuit - so are wires and connections. Many break right at the rubber where the wire enters the connector. Pull firmly.
Old 01-17-2019, 06:25 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,530 Likes on 3,783 Posts
Originally Posted by Scout
I had the same almost exactly, but on a older bike. It was the cam position sensor.
Got a question and thought on your post. Only first and maybe second year TC had this. It is below timer cover on right side. Bean counters decided it was not necessary.
My understanding is all it did was set a code if the crank position sensor and it did not jive.
​​​​​You are saying only sensor died and it caused same issue as above? Did it set a code?
To the first poster, does your neutral position switch work fine?
Old 05-03-2023, 01:34 PM
cjerkins's Avatar
cjerkins
cjerkins is offline
Stage I
Default Same issue, same year, same model
Jackie Paper, How did you solve this problem?
Robottom
06-16-2015 08:56 PM
cuda67bnl
04-12-2011 07:20 AM
p51bombay
11-03-2010 06:40 AM
brickie
05-31-2010 10:41 PM
cewood
12-04-2007 06:10 AM
Quick Reply: Stalling, bad idle, hard restart.
