Are all EFIs created equal?
Thinking of converting my carb'ed chopper to EFI with an aftermarket kit.
The $2k price tag is gonna feel like a kick in the dick but I need the bike to start in cold weather when I don't have access to an outlet to plug in a heating lamp.
The 2001 Fat Boy is the first year of EFI for that model and it fires up in single digits without complaint.
Wondering if any EFI is going to fire the bike right up no matter the temperature or are some aftermarket EFIs better than others?
I actually don't want to install EFI but how else do you get a carb'ed bike to start in single digits? (with no access to an outlet overnight)
actually...if your bike is tuned properly, the carb properly set up, your isgnition, starter, battery, all working properly...and you properly use the choke, a carb bike should kick right over. An EFI bike has to crank a while to get everything in synch. Where as a carb bike as soon as it starts to crank, curl mixture is drawn into the cylinder. Sure, EFI takes thecguess work out of the proper amount of throttle and choke. But, $2K seems a lot to fix this issue.
JMHO...
JMHO...
So does that mean colder temperature=less twists?
