No fire with Twin Tec on Softail
Ok so here's what I've got. OE 2000 softail harness with the TSM bypassed using a Grip Ace controller and Daytona Twin Tec ignition module for a 96" TC. To preface, this bike ran with this exact layout previously, then the oil pump went bye bye and it got replaced. Pulled oil tank and flushed it good. Now I have no spark during cranking. Checked all my connections behind it think something got pinched, cut, knocked loose, whatever. Bike turns over excellent on starter, got compression, battery voltage is perfect and all fuses are good. What I've checked so far:
Run/stop works fine, good power during cranking
Crank Sensor replaced, both old and new crank sensor check good
Check power to ignition module during cranking, checks good.
Power to coil at key on and during cranking is good
Grounds are good
coil was checked and replaced, both check good
No signal from the module to the coil during cranking
Bank angle sensor shows to send ground out to module (I can't find out if that's right or wrong, makes sense that it's correct though)
MAP sensor check good
Replaced Twin Tec module with stock HD module no difference (but it's a dyna/road king one and the part number is different, however no one can tell me if they crossover or not)
And yes it has gas in it............. what else am I not thinking of?
Grounds are good
Grounds are good
Grounds are good
I though all 96 ci TCs were fuel injected so which DTT module did you use? Single connector or dual?
Wiring for the single connector model.
http://www.daytona-twintec.com/downl..._OE_Wiring.pdf
I read it wrong also. I suspect he has a 96 ci motor (07 to 10 motor). Since he is using a 2000 harness, it will be a 2 connector DTT module.
Will need to ground the tilt sensor wire but should get spark. IIRC DTTs will spark with the plugs out but only timed for the rear cylinder. He could try installing the plugs to see if it helps.. I'm not sure if Schroeder ever did a module with cam sensor but if he did the and the DTT is early he might need one..
Sorry, been slammed at work and forgot I made this post actually. I actually saw that I'm getting no signal out from the module to the coil, not just no spark. I worked my way back to it, instead of just jumping to it first. I am sending the module back to DTT tomorrow if I get the RA from them. Just sucks because it was fine before, just only made it a half mile on the oil pump lol. That's my luck though.
