Stock tune with SE Pro Street
I just got my Pro Street tuner, and won't have my muffler and A/C for a bit. I want to adjust throttle progressiveness with the stock tune, but when I look at all the tunes available for my 2019 Sport Glide in the software, stock is not an option - Stage 1 is the lowest tune. Is there a way that I'm not seeing to download my stock tune, modify it, and download it back to the bike?
If you are having a problem with the throttle response, take it back to Harley, will be covered under warranty. Maybe I'm not fully understanding what you are trying to accomplish, but my advice is to keep it stock until you get the other parts of your stage 1.
Here is a link to a thread I just started a few days ago, great information: https://www.hdforums.com/forum/touri...motor-2-a.html
To put it simply, I want to increase throttle aggressiveness from stock settings, as I find it very lazy, and I'm used to modifying it on my other Harleys. I should be able to grab the stock tune, modify it, then load it back up, but for some reason Pro Street tuner doesn't have that option, as far as I can see...
I know you can't simply "...grab the stock tune and modify it...", because you can't modify "everything" in the tune any more.
I'm more familiar with the SE Pro Super Tuner, aka "race tuner", but I have had several conversations with our senior tech, and he has told me, very clearly, that the capabilities of the Street Tuner are dramatically reduced from the Super Tuner. Some parameters in the tune can only be adjusted by very small amounts, and some changes can no longer be made. You may need to talk to someone who has used it extensively, and you may find out that you can't change throttle progressivity with the Street Tuner.
i
