Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 1999 ex police Electra glide no power to coil I turn it on put run switch to run it activated file pump and all other components just not the coil can someone help
I have an update on my electrical issue I'm getting momentary power to the coil when I turn on the switch when the relay timer for fulepump timed out and relay clicks off it turns power to the coil off as well I can't figure it out
That is what it is supposed to do. What is your actual problem?
