Looking for input on possible electrical problem on 1996 Road King
You've gone from start and stumble to no spark? Which sensor did you get, the carbed version or 32448-98B? Double check the connections from the Cam Sensor to the ECM at the triangle connector. No doce there and you went with the cheaper carbed version you may have to step up and buy the correct sensor for the bike. If that's not it, you should probably test the whole electrical system. https://www.hdforums.com/forum/evo-c...ng-system.html
I found my problem and I had the bike running lastnight. My dumba$$ left the ignition coil unplugged when I was checking the volts the other night. I plugged it in, had spark and got the bike running. I haven't ridden it yet tho because I am putting a new exhaust on it also and ran out of time lastnight but with this new sensor I'm hoping the bike won't sparaticly stumble anymore while riding it. Thanks for all the answers fellas
DR_DEUCE
10-21-2010 08:38 PM
