2005 Ultra 88 EFI backfiring popping
Kickstand103 (04-23-2019)
Discovered fuel pressure regulator housing broken & spraying fuel. Housing & regulator sold separately. I’m only going to replace the housing.
Too cool. Seen a few of those plastic housing cracked and open with o-ring hanging out on here when people go in tank.
I can understand sputtering but why does motor pop back thru throttle body when fuel pressure is low?
Was the backfire thru the throttle body when cranking and starting and as it was dieing running down road?
Backfire was bad & out thru throttle body. I didn’t realize low pressure could cause that, just like an intake leak, but it did. Now I’m wanting to buy a check hose & fuel line so I can make a fuel pressure test gauge setup. That would have helped in initial diagnosis. Found used parts on EBay.
Indy Cruiser
02-09-2011 09:23 AM
tarheelrdr
11-01-2010 10:06 AM
