Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
it could have cops installed but a hd tech would know where the plugs are, you would think???
they do make 3ph systems and high output. the series wound coils run higher temps, when mine failed, it was the connection at the winding output and vr pigtail in the primary. i had issues for several months and external testing failed to show anything till the wire burned nearly in two.
picture are worth 1000 words and will add to the diagnostics from fellow members.
Stock location would be under the right side cover just in front of the saddlebag. It’s possible that it has been replaced by an aftermarket unit which would be totally located in the timing cover (cam cover).
