HD Newbie. No Fuel??
HI all. I am new to the HOG family. I just purchased a 2008 Electra Glide Classic with 58k miles. Previous owner didn't ride for 3 years and bike sat on a trickle charger and was fired up every few weeks. Previous owner tried to fire it up when I went to look at it and found it wouldn't fire up and idle. It would turn but not fire. Assuming it was a fuel pump issue, he replaced the relay and it fired up. He drove it to the car wash and hosed it down and then on his way home it seemed to run out of gas. It had fuel so he open the tank and found the fuel lines were cracked. He replace the lines coming off the pump along with the filter and strainer and the bike fired right up. It starter over and over again with out any issues and even ran around town on it. I went down to purchase it the next day and now it won't fire up. He acts like it isn't getting gas. I went ahead a bought it for $700 less than what he was asking since it wouldn't idle and stay running. What do I check next? It sounds like the fuel pump is engaging, but could it still be faulty? I disconnected the tank from the line at the quick disconnect and some fuel comes out. Should I proceed with a fuel pump change out? Thanks
Are you sure it is a fuel issue, and not a spark problem? If you hear the fuel pump pressurize the lines on start up, then it is probably OK. Is there fresh gas in it? recheck the work that the PO did in replacing the lines, and filter. Test the fuel pressure. That will tell if the pump and regulator are good.
rclong211
08-17-2010 07:22 PM
