Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 2005 Road king police, I rode it for about 35 miles and suddenly I lost power in one cylinder. I have spark on both plugs, bike starts right up, changed the ECM and still wont fire in one cylinder?
What codes are you pulling up? Have you checked the connectors on your injectors?
My son's 2004 FXDLI started running rough and smelling gassy a few blocks from the house. He limped it home and ran the codes which indicated that the front injector was not working and we found that the plug had corrosion and was intermittent. Cleaned it all up and put some dielectric grease in them and back on the road.
I have same problem on 2005 FLHRCI Road king . Have tried everything and still rear cylinder wont fire. Did Compression test and it was good but still rear cylinder is cold while front cylinder is hot. Did you resolve your issue if so how ,?
