Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Ignition/Tuner/ECM/Fuel Injection (https://www.hdforums.com/forum/ignition-tuner-ecm-fuel-injection-55/)
-   -   Backfire, won't start, Fatbob, please Help (https://www.hdforums.com/forum/ignition-tuner-ecm-fuel-injection/1285589-backfire-wont-start-fatbob-please-help.html)
robyb May 26, 2019 07:28 AM
Hello, i am new to this forum , i am here to ask for help for my 09 Fatbob
So , i own a 2009 HD Dyna Fatbob fuel injected bike , everything was fine until one day it had trouble starting , it started but was misfiring with black smoke. Then a couple of days later , when i want to start it, it just cranks and misfires.
I read here on the forum that it might be the coil or the crank case sensor ( i got error p0373 )
I changed the the coils and the crankcase sensor, still the same problem . Now what ?
just wanted to mention , the bike is stored in my garage so no water problems , i checked the ground wires, and the wires coming from the crackcase sensor to my ECU.
Any information will be useful .
nevil May 26, 2019 12:05 PM
How old is the battery? Get it fully charged and load tested.
Possible leak in the fuel line inside the tank.
Do you still get the code?
robyb May 26, 2019 12:17 PM
i bought the battery this year and have it fully charged , i will try another battery tomorrow, i just checked the lines in the tank with flashlight and they seem OK .
Also , i have new plugs ( tried to start with the old ones as well )
I have no error codes.
nevil May 26, 2019 12:21 PM
Don't try another battery until you have your load tested. Even if it shows full charge at rest, it doesn't mean it has enough under load.
robyb May 26, 2019 12:29 PM
So , battery voltage
12.6v sitting
12.3v ignition on ( and lights)
9.5v ( lowest) when cranking
it misfires and black puf of smoke comes out the exhaust
bustert May 26, 2019 12:59 PM
below 10 under crank is considered bad.
do as mr. nevil suggested, charge and do two back to back load tests, first is to remove and surface charge and second to see what is going on.
if coil saturation is low, the output will be low so you will get a weak spark. if the cyl loads up with fuel, it will smoke black and hard to start.
robyb May 27, 2019 09:18 AM
I tried with my car battery , same problem , so it's not the battery.
Any other ideas ? anything would be useful
Max Headflow May 27, 2019 07:22 PM
Are the plugs wet?
Bass Player May 27, 2019 07:39 PM
You said you stored it in your garage. My question, how long had the bike sat without being run?
robyb May 28, 2019 12:57 AM
The bike was sitting about 4 months , and the symptoms came gradually , it started harder and harder , now it will not start at all .
@Max Headflow, no , no water issues.
© 2026 MH Sub I, LLC dba Internet Brands
